Hyperlink Problem
Discussion in 'Wisdom of the Master Archive' started by Vipoid, Dec 5, 2013.
  1. Vipoid
    Vipoid Necromancer
    (If it matters, I'm currently running Firefox)
    Anyway, I was trying to post a link to my 'SGK AND Master Necromancer at 2000pts' thread.
    However, when I try copying the address and using the hyperlink button, something seems to go wrong: This Thread.
    (In case you can't tell, the only words I wrote and highlighted with the Hyperlink button were "This Thread.")
    I also tried just pasting the link directly onto the page, but got similar results:
    http://www.vampirecounts.net/Thread-SGK-AND-Master-Necromancer-at-2000pts--27168
    For some reason, it only seems to be this thread that causes an issue - I've tried hyperlinking to a few different threads, and they seem to work fine. o.o
  2. Lynks
    Lynks Lord of RAW Staff Member True Blood
    The issue is with the SGK abbreviation- the inclusion of the scroll over text unfortunately breaks the link.
  3. Vipoid
    Vipoid Necromancer
    Ah, I see.
    I'll bear that in mind when naming threads. ;)
  4. Lynks
    If you would really like to link a thread but you are having this issue you could use a URL shortener like TinyURL and then rename the hyperlink
  5. Disciple of Nagash
    Yes this is a known problem which is very irritating. Hopefully this will not be an issue when we transfer to new software.
