* Basic Spell: Soulsteal. Direct damage, 12" range. Nominate a model. Caster and Target roll 1D6 and add their unmodified leadership. For each point the caster's result exceeds the targets result it suffers 1 wound with no armour save allowed. The scaled up version has an increased range.
1: Face of the Reaper. Unit Buff, 24 " range. Targeted unit causes fear. Caster may decide to make it cause Terror for a higher casting value.
2: Embrace of Laniph. Direct damage, 12 " range. Nominate 1 target model. Roll 2D6 and subtract the target's Strength. The result equals the number of hits the target takes, wounding on 4+ and ignoring armour saves. The scaled up version has an increased range.
3: Soulrot. Hex, 24 " range. Targeted unit suffers a -1 strength and toughness. The scaled up version is ALL enemy units within 24 inches. Lasts 1 turn.
4: Dark Despair. Hex. Remains in play, 24 " range. Targetted unit suffers -3 Leadership. The scaled up version has an increased range.
5: Bajuna's Fate. Direct damage, 12 " range. Nominate 1 model. Roll 2D6 and substract the target's toughness. The result equals the number of hits the target suffers, wounding on 2+ and ignoring Armour saves. Should the target survive, it suffers stupidity for the rest of the game.
6: The Purple Sun of Xereus. Power Whirl, Remains in Play. Place the small template in base contact with the caster and roll the artillery dice. Multiply result by 3. The result is the number of inches the template moves. Each model touched by the template, except for the wizard himself, has to pass an Initiative test or is removed from play. No saves are allowed. If you roll a misfire, place the template above the caster himself, roll a scatter dice and 1D6. The result is the number of inches the template is moved away from the caster.
The template moves at the end of each following magic phase, roll the artillery dice and a scatter dice to determine direction and range. If you roll a misfire the template is removed. The scaled up version uses the 5 " template instead.
