Using Dark Elf models for vampires
Discussion in 'The Necrarch Workshop' started by warhawk, Sep 13, 2014.
  1. warhawk
    warhawk Zombie
    So i got a shadowblade model and going to be converting it some to make it more vampirey. Anyone done this befor or have any ideas on what one could do for that?
  2. MasterSpark
    I don't know how I would convert that model to be more like a vampire, but I think you could use him as he is right now. Just give him a more undead paintjob. The older fluff says that Blood Dragon vampires sometimes ended up as assassins, and this guy looks just right for that.
  3. Sanai
    Sanai Stylish Deviant True Blood
    I have seen plenty of dark elf models used as vampires- particularly the plastic sorceress, and the elf swordsman from mordheim (Aenur, Sword of Twilight) being particularly good examples.
    Myself, I have used Dark Eldar as vampires- particularly the Lahmean Poisoner.
    Generally the right paintjob is all you really need (though with the Lahmean I had to file off some generator looking backpack things).
    Heck, shadowblade doesn't even have his mouth or ears visible, you you don't need to worry about him not having pointy teeth or having to file down his ears.
    I think a predominance of red & black on the model, particularly on the armour, or some kind of freehand with skulls/bats involved would help sell the idea that he is a vampire though.
  4. El Syf
    El Syf Crypt Horror
    Yep the mordheim elf swordsman is a good shout, been using it as one for years now.
  5. Markond
    Markond Skeleton
    I would swap the broken elf architecture on the base for a gravestone of skeleton, or remove it entirely. Swap the left arm for one with outstretched fingers and have an ethereal skull rising up toward it to suggest necromancy. I would also suggest sculpting the vague outline of faces on the inside on the cape, similar to the ones in Vlads.
  6. warhawk
    warhawk Zombie
    Thanks for the ideas. Definitly like the ones that markond gave. Now to just see what bits I all have to do this all.
