Anilar (Orks) vs Bishop (CSM) - 6th - 1500 pts
Status
Anilar
Wight King
#76
So far 3 wounds on NM3 at normal armour save. Might shoot a little more on them, not sure what my large mob of shoota boyz should be shooting at, or if they should be running.
Warboss and ardboyz, shooting at cultists in ruin. Same stats of sluggas and the warboss twinlinked shoota, apart from his ability to reroll. First two dice will be the warboss.
Anilar
Wight King
#79
5 ap 6 wounds. Guess you will be using the 4+ cover save. Guess I should have used a grenade also, oh well.
Time for the Battlewagon, three big shootas that can shoot at NM2
Anilar
Wight King
#81
So far.
3 wounds on NM3, ap 5 and 6, so they can use there 3+ armour save.
5 wounds on cultists in ruin, think the best they can use is 4+ cover save.
1 wound on NM2 ap 5 so ordinary 3+ power armour save.
A crew shaken and explode result on R3, unsure if it have cover save.
Just missing my large shoota boyz horde in the shooting phase, but need to see what happens to the rhino before I decide where to waste there shots.
Bishop
#82
Anilar said:
Not sure if you have cover save, but here is the penetration rolls
I think I'd have cover from half the unit.. so.. covers in the same order you rolled you results in..
Bishop
#83
Can the Ob2 even see the NM3? Neither of us are in area terrain. (I don't think you rolled to try and enter it.. )
Bishop
#84
That was my saves... if you did, and I missed it.. (more worried about the assaulting then the shooting :D )
Bishop
#88
1 NM2 dies..
Rhino 3 explodes... you need a radius roll... Rhino 3 is empty.. so no passengers.
Anilar
Wight King
#90
Not near a rulebook, ill look up the area terrain stuff tomorrow, but yes didn't enter it, moved my unit to its outskirts.
Anilar
Wight King
#91
Don't see anything that make area terrain prevent things like shooting or assaulting. There is more or less true LOS in warhammer both types now.
My large Ork shoota boy mob will shoot at NM3, 3 Orks with shootas in range, and 3 Orks with big shootas.
The 3 shootas first
Anilar
Wight King
#95
So another 5 wounds on NM3, you have 3+ armour save against all the shots.
Assaults next.
Ard Boyz with warlord will assault your Cultists.
OB2 will assault NM3.
Will await your armour saves and overwatch shooting before moving.
Status
