Bishop (Beastmen) vs Bloodsucker (VC) - 2500 pts
Status
Bishop
#26
Now that I'm on a computer, and not my BB. :D
The quick start instructions can be found here
If you need Battle Chronicler, there is a link in the quick start instructions.
You need to download the map from the XML link at the bottom of this post. THen you would be able to open it with BC. I will add the armies to the game file, since this is your first game. It'll make things easier.
To roll dice you need to use the dice roller text boxes.
How many dice: (a number from 1 to 50)
Roll required: (must be in the format of 1, then + / -) example, if you wanted a 4+ to hit you'd enter 4+
Seperately / Combined: normally seperately (combined would be for something like a Ld test)
Roll Dice: must be checked off to roll the dice
Scatter Dice: is only used to roll a scatter dice.
Bishop
#27
Actually, use this XML file.
I have the armies defined in here.
I made a few assumptions about your unit formations, you can change those if need be. Also, the sizes of Mortis engine and Terrorgheist... as I dont have either of those models.
#28
i have instaled it but i still cant fiquered how to roll dices i press the buttons you say i should press but nothing happens the dice text box is in the bottom of the forum or is that not the real one
Bishop
#33
Ok, that's Invocation of Nehek, Vanhel's Danse Macabre, Hellish Vigour, and Gaze of Nagash.
Bishop
#50
You need to export the game file and then reupload the map...
I think I have some more instructions here somewhere..
Status
