Bloodbeard's Corrugated Scrap Metal Wall Tutorial
My friend Bloodbeard runs a blog with a cornucopia of hobby goings-on in it, not least scratchbuilding of terrain! Here he has kindly wished to share his latest tutorial with us, for all your ramshackle need!
Be sure to check out more of the stuff on his blog if you like what you see here:
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F6BRlt3q.jpg&hash=c88f287d28c3967de121bcab33f75f3e
Tutorial: Corrugated Scrap Metal Walls
I found the tool for this build a long time ago. Don't know how I ended up with it, but it was during long hours of searching china shops for useful stuff. And I found a 'toothpaste squezer' - perfect tool! Greenstuff World have since released the exact same item under the name 'corrugator' - but it's a toothpaste squezer and it's half price like that.
Best tool you'll ever find for $3 including shipping.
GSW is an awesome shop however, so it's always a good cause to throw money at them.
Made these for use in all my sci-fi and post-apoc games. To be walls for Alexandria and Woodbury in The Walking Dead or in Last Days. As part of the Wasteland in Scrappers and This is not a Test. And they are 3'' compatible with Deadzone. Also fitting for Ash Wastes in Necromunda or Killteam (man there's a lot of cool games).
As always go to the bottom for showcase photos.
Materials
- Thick card or mdf for bases
- Cardboard, plastic card, foil trays for 'metal plates'
- Superglue (lots!)
- Hot glue gun
- Sprue (lots!)
- Popsickle sticks
Step 1: Bases
Cut out a bunch of bases for the walls. I've made sure mine are 3'' compatible for a Deadzone grid. Made then 1,5'' wide, so they will stay in place and not fall over. I've used thick 3mm cardboard for the bases.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FmA4AdRP.jpg&hash=3221485bffed753e92ee4ba1d6a5f4e3
Step 2: Sprue and hot glue
Cut a lot of poles from old sprue. Shave off small bits, to make the poles a bit uneven. Also try and find some with an angled piece, saving glue connections later.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FAYI9hrv.jpg&hash=bdcfd02dc3265dc499875ee702a59e49
Using the hotglue gun (and I find it's much better than super glue) attack them to the bases. A lot of them, more than you think.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2Fy7OsAe3.jpg&hash=9d20770c92fae23f79d18d7095278ba7
Step 3: Walkways
Prepare the walkways, glue some sprue to the angled pieces.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2Fvt0nqq5.jpg&hash=4abdec1f8281d6e1792db105d377d80d
Step 3: Corrugated plates
Take out you toothpaste squeezer and make a bunch of metal. I used different thickness of cardboard and aluminium bbq trays. Thought was to get different textures on the finished walls, but it doesn't show well. Cardboard is easier to glue however.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FerEJXrg.jpg&hash=e22446828129606e81a8571d3a985566
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FJeCDm9m.jpg&hash=67823ce5f4e9a2b9fb06acbcfe1cd6b9
Step 4: Glue... All over your fingers
I use super cheap super glue from china. I buy 100 tubes at a time, it's good for projects like this. Start from the bottom and just mix match plates and work towards the top. Make sure to have the lines go both horizontal and vertical.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FlOO3VZZ.jpg&hash=aa363fd63f622691cf1547ba0466643d
Step 5: Strengthen it
I took some sprue and added to the front and the back of the walls. It adds some more strenth to the build and is a good soak point for wash and quickshade. I've also build a couple of ladders from sprue.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FtuhajwX.jpg&hash=8ca72aaf734544e8a4e808ce7f6ce945
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F0dpwADL.jpg&hash=dbb459351806bb12d793277782e8bccc
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FCdr9jI4.jpg&hash=4cd8a3ec76fa9c5baae58a79a4302d4f
Step 6: The gate
Originally I planned to make a magnetized gate. So I glued on two old rusty nails. But after doing this I found that the gate for my prison does the job well enough.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F5eKJVzm.jpg&hash=2cc96faad0ed02e14a52aa6d82dfc213
Painting and Basing
I base coated the walls with a cheap grey rattle can and the 'floors' with a cheap brown. . Then I picked out a few plates on each section in a different color (using the same three colors on all). Another bunch on each section and all sprue was painted with a mix of 'rust'. Using a wet palette I add various metal colors, giving lots of different nuances.
The dirt was painted with cheap brown acryllics and drybrushed with grey.
The walls were all given a heavy layer of army Painter Strong Tone. Mixed some different grass types for the bases and ended with a couple layers of mat varnish.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F7IgDMCL.jpg&hash=179d6435879fbe7a60e067f7c84a7b9e
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FQZVkqBS.jpg&hash=5ad6d51ffbcd1dab52682e7f57324b4a
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FeK49ym9.jpg&hash=9d5b75d64b6e8e8a7a889bbf900e96a3
Showcase
And here's the nice finished result.
The original idea for these walls were to be used in The Walking Dead as part of Woodbury and Alexandria. With my farm and prison, I'm set for the first 180 comics or so.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FNhD8LUz.jpg&hash=53e456c0ce66e374c86b58dc92d3f0fe
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F1gwUVLI.jpg&hash=baa49a8821def36abee63e28e188df68
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FiUT4ItW.jpg&hash=90410a2631607e263eb37bd8ceabf3b9
The builds were done in the 3" system to fit neatly into games of Deadzone and my other industrial terrain.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FK94f0Z9.jpg&hash=5477417c9824e826dc1f41b2d9a3cd17
proxy.php?image=https%3A%2F%2Fi.imgur.com%2Fye4UGRj.jpg&hash=2cc26a14e7ba28aa7dac7a324d5b6c21
And here's the walls set up on a 3'x4' mat. Taking a lot of space, making a Wasteland map for This is not a Test or Scrappers.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FoLqMoKh.jpg&hash=e8d0afcc06eaf48ad82b3bea571c9c42
