RE: Random Charges
I think that double movement plus a dice roll is too far... and in the case of the d3, not random enough.
Under previous editions we'd have double movement, period.
most infantry units would move 4 / 5 inches, and thus charge 8 / 10.
If using 8th rules, they'd average 11 / 12 inches respectively, which is fine. However, at the extremes it'd be as little as 6 / 7 and as much as 16 /17. IMO, this is WAY too much variation.
What about something like: 1.5 Movement plus d6?
Is that too complicated?
For Move 4 units, this would give us a range of 7 to 12, with an average of 9.5 (which is only slightly longer then previous editions)
For Calvary units (and anything that is Mv 7 or higher) should be 1.5 Mv + the highest roll of 2d6.
Given a Mv 8 unit, this would give us a charge roll of 13 to 18 (which again is close to previous editions).
This should give us something that is random enough to eliminate always being within charge range (experienced players could frequently get charges off vs a unit that was only 1" slower in previous editions... I know).
Any thoughts on this?
