How Charging Affects Close combat
logan054
2,628
Colchester
I think one of the biggest problems with 8th is the fact chargers do not get tho strike first, this really hurts things such as Low I Cav and great weapons. Personally I feel step up is more than enough of a rules change to make infantry Viable, the way I works in 8th armies such as WoC and elves have such a massive advantage, +1 to charge really is not enough of a incentive to charge, why should a spearmen charge, the lose a rank of attacks for +1 combat res, if we are talking about saurus they gain nothing, at least if they struck first for charging they would have a reason.
This change then links in with ASF, with changing back to charger strikes first I suggest returning ASF back to how it was in 8th ed.
RE: Close combat
I think that the easiest fix for this is too allow the Charging unit to gain some kind of bonus that will ensure or make them more likely to strike first.
My thoughts are:
Calvary units gain In 10 on the turn that they charge.
Non-Calvary units gain an In bonus, say +2 In (max 10) on the turn that they charge.
This keeps it as simple as possible without rewriting other rules.
If we wanted to change ASF back to the way it was in 7th, then simply giving the charging unit(s) ASF for the turn would also correct the issue.
RE: Close combat
I think a blanket +2 Init for charging is fair.It also makes sense that the act of 'Taking the Initiative' gives you a little extra of it.
RE: Close combat
Perhaps we should also make it so that charging into the front of a spear or pike unit negates this bonus.
RE: Close combat
i think the problem with just +2 is with the Low In armies such as Dwarfs, Orcs, etc, because such armies will never strike first just have no reason to charge. With Dwarfs they may as well wait for you to come to them and shoot, saurus with spears are never going to strike first and may as well hold back for that extra rank of attacks.
Charging spears to the front negates the charge bonus is certainly a good idea but this still would not help low I armies, WoC will still rule supreme.
Personally I think it is just far easier, charger strikes first, ASF always strikes first, maybe have it so great weapons strike in In order?
The thing is large units of infantry are still going to get to strike back thanks to step up, unlike now it might matter if you fail a charge.
RE: Close combat
I think spears should always strike first when being charged, unless they are being charged in the flank or rear, as well...spear....long....braced ready... you kinda have to brave the spear and get past it before you strike with a sword.
and certain troops are always going to want to stay resolute and recieve a charge, we dont need it to justify every single troop type charging over standing fast.
RE: Close combat
Well.. a knight charging with a Lance is going to have a longer reach then an infantry armed with a spear. And the momentum of the charge is going to hit the unit anyways, even if the knight was "killed" by the defending spear unit. I would agree that Pikes, on the other hand, might gain such a bonus.
That was my logic on giving Calvary In 10... maybe it should Calvary armed with Lances only?
I guess we need to ask: is ASF something that we want to revert back to 7th rules?
If so, then chargers can gain ASF
If not, then chargers have to gain an In bonus as well as ASF
RE: Close combat
Why would they need an init bonus? Do you intend to give cav re-rolls? I wouldn't give cav ASF.I'd resolve it 1-ASF.
2-Chargers.
3-Remaining combatants in reg init order.
Obviously there will be a little fine print.
As far as pikemen/spearmen are concerned,We should probably come to consenses over the rule itself,and then modify them accordingly-if at all.
RE: Close combat
ASF is certainly another option, the only thing is how this relates to the interaction between SoA and other armies, I just thing the HE army is balanced with the intention of them striking before everyone rather than just troops.
What it does mean is that HE units still have a advantage against armies such as WoC and using spells like in lore of shadows that reduce I does not effect this. Being T3 with rubbish armour I think they really need to retain this bonus, the current bonus is just to good, if I play HE I may as well just leave my marauders in the deployment zone, they can't perform in combat even against spearmen :(
As for spears before you start to worry about how weapons work you need to get the core mechanic of charging right, then you worry about weapons interact with this.
RE: Close combat
No, I don't think that Cav needs to reroll... they just need to go first when charging. Even more so then Infantry, given that the units are normally much smaller. I guess I can handle the pouncy HE going first still. :rolleyes:
Personally, I hate the army wide ASF. I understand that they need it... but it should be limited to frontal fighting only.
RE: Close combat
I think one of my early ideas I had had for cav was that Lances provides the ASF rule on the charge but are limited to one attack on the charge, this was before I had thought the rerolls should be removed for ASF, I am with Bishop, i hate ASF as a armywide rule, personally I think it should be removed and either replaced with something more balanced or just make the models cheaper.
RE: Close combat
Just a note, can we try and limit how many threads we are discussing or you run the risk of too much slowing the project down.
We have 3 at the moment, lets keep that at the max.
Now this thread states close combat which entails far too much for one thread - hence I have changed its name to How Charging Affects CC.
I do agree charging should be much more of a benefit, but it should also reflect the army as well. Even with charging Ogres are quite dim witted whilst DE are not.
The simplest way for me is:
When a unit charges they double their Int (rounding up) for the first round only.
Enemies that have ASL (excluding stomps) do not double their Int but strike in Int order.
It means that most units that charge do stand a decent chance of striking before their opponent unless they are very fast such as elves which would be expected. The
NOTE: This is not the thread to discuss unit types such as cav or weapons such as lances. This is to discuss the basics, you then design the special rules once you have the basics on place.
Well I will just touch on the idea of double I, the main problem with this is that some armies will still not really be gaining a whole lot bu charging, , if we start with I2, this only doubles to I4, against anything with I5 (Elves, WoC) this unit type will still be striking last so the advantage for charging is lost, I1 at best can hope to strike at the same time a Orc, this really solves nothing. You then have to decide how you want ASF to inteact with this, if you retain the rerolls then anything with I3 is now I6 and this ASF no longer grants the rerolls. I have no issue with this but I do think I2 and below models are really getting the short straw here. This is why I suggest you just have a blanket chargers strike first rule, this allows ASF to revert to the old rules and suddenly become more balanced. He work how they have been designed to work (cause damage before they fall apart like paper), large units with the numbers can still deal the damage. The primary unit this nerfs is units such as CW, SM, etc, for these units it dosn't matter if they charge, they strike first with lost of high strength attacks, this really leaves models like Ogre with short straw.
GW striking in In order on the charge has my vote,its gives a few underused units the buffs they need to be playable.
How about then that charging units have I10 for close combat purposes in the first round of combat?
This then means pretty much all units get to strike first if they charge except against ASF, which is how it is supposed to be? ASL strike in Int order if they charge?
To be honest if your going to do that you may as well just have the blanket rule of chargers strike first, again however this depends on what you want to do with ASF rule, if you keep the rerolls is the intend that they lose the rerolls if they are charged, if that is the case the striking at I10 is fine, if this is not the case then just striking first makes sense as it has no effect on the ASF rule. If you want to lose the rerolls then it doesn't really matter, its just your saying I10 when you may as well just strike first to keep the idea that 8th as brought into play and give the illusion In is important.
Personally I feel that those with the ASF rule should strike before chargers (to the front at any rate - however ASF needs discussing in detail later). It is the nature of the rule, and one that I think the fragile HE do actually need.
So I10 does work better for me, because against anyone else they should strike first, and it does give them the edge against ASF if we keep the re-rolls in.
So yes for me, I10 on the charge, striking in I order for ASL (not including stomps) works for me.
If you are going to keep the reroll ( I am personally against this) then I suggest you take the route of blanket strike first on the charge, HE still ASF and still get the rerolls when charges, I don't think it makes sense just because your running really fast at someone they are going to be less agile which is the whole reason for the rerolls, then again I am against the whole rerolls, it wasn't needed in 7th and really don't see why it is needed now. Regardless of having strike first on charge (Not ASF) or I10 HE have the advantage back that the army was designed around in 7th and thus to rerolls is no longer needed which frankly is ridiculous against some armies.
Firstly the think you have to remember is that we are trying to fix the BRB, not all the armybooks as well. HE having ASF is broken yes, but that is due to its armybook, we also need to see how this applies to individual units.
Whether or not ASF still has re-rolls (I'm not sure on that either) is again something that needs to be confirmed once we have basics out of the way.
So with that in mind, why don't we disregard ASF for the moment - that can be tweaked later to get the desired affect.
What we need to do at the moment is to look at how the charging works - I think we are all in agreement that charging units should hitting the unit they have charged first most of the time.
With the current rules we can either do that three ways in my eyes:
A blanket rule stating they hit first.
Giving them I10 on the charge, which with the current ruleset means they hit first most of the time.
Giving them ASF.
Personally I still stand by the I10 for the following reasons:
It is not a blanket rule which then needs to be countermanded for various items with various rules. Simply giving some ASF counters this if that is intended.
If necessary we could have Hexes affect it, which could be very good tactical wise.
You don't have the ASF vs ASF issue you would have with the last option.
The only issue I see is working out how ASF works with it, which to me is a problem with ASF, not this rule.
Init 10 is good for me.It's simple yet it allows for interesting exceptions.I think all the basic mechanics should remain uncluttered by alot of sub-clauses.
I don't see a prob vs ASF,troops w/ ASF will still go first but will almost never get rerolls.
The straight "charging units strike at In 10" is probably the cleanest. :thumbsup:
How this interacts with ASF, GWs, ASL, or whatever else, is really not relevant to the fact that we want charging units to strike first on the turn that they charge.
While I agree we are not trying to fix army books we should think about how these rules interact with the army books, at the end of the day I see no point in doing this if it breaks army books, who going to agree to use it.
This does not change the fact the fact we have to consider how ASF interacts with which ever method we choose for striking first, allowing rerolls or not totally changes everything.
Actually I think you are forgetting someone, the spell only lowers it by D3, the highest In unit I can think of is 6, your average being around 3/4, in most cases you are going to have to lower the I value by 6 or more. You have plenty of tactics based around these spells as the game standards, a nice spell combo is -D3 In followed by pit of shades. You can also use these spells to stop a unit from getting Rerolls to hit.
At the end of the day I10 on the charge is no easier than chargers strike first, we have been playing with this rule for go knows how many years. I10 over strike first in my books as I said really depends on what route you want to take with ASF.
Personally I don't see the point in I10, the only difference is how it works with ASF which as I said which makes no sense at all, what bishop is totally missing is me and DoN are both saying chargers should strike first, the difference of opinion is the method, mine is based on how DoN interacts with ASF. So in short Bishop, yes it is very relevant it interacts with other rules, if you ignore this you are either going to have needlessly change other rules to make a new rule or come back and change the rule you just changed in order to make it work better.
Logan - I think you need to stop saying people are missing / forgetting things. Its an assumption on your part which I assure you so far you have got wrong twice by saying it to me. Unfortunately if I typed out everything in a post to cover every variable, my posts would be extremely long ;)
For me it boils down to:
We both want chargers to hit first yes?
For me in that instance I only when them to hit first guaranteed on normal situations. I still want them to be affected by Int modifiers, strike after ASF etc. I am also thinking of things such as spells and weapons that give I10 - I think charging should strike simultaneously but not before.
So for me I10 works for me. I appreciate it might not work for you, but then we all have different opinions.
