Summoning and you. A Lore guide.
Demian
1,245
Hello brothers and sisters! I wished to make a guide about Lore of Undeath and all/best summoning chioces you have, while using regular casters, or Arkhan/Nagash. It's going to be a bit of a long reading, but as a guide, I hope the colors can point out which part interest you more. Also, I'll leave a reply for every summoning spell, so that information is not crumped up. As this is my first guide, I can and will make some mistakes and I'll appreciate the advice and will correct as I need as soon as possible. Also, if this guide proves useful, I'll request to make it a sticky! :D
(EDIT: Thanks to @DarkProphet for corrections made :D)
So, here we go...
Gray Text: Is the one thing I don't recomend you summon, either for the overkill of models, like Zombies, Dire Wolves, etc. or the much better options it opens, specially with Arkhan or Nagash.
White text: those units you can consider using, but there are probably better ones, because...
Yellow text: these are the ones I highly recommend summoning, depending on your list and playstyle of course. These are the ones that can change the game entirely and grant you victory!
Ryze - The Grave Call
Basic Version, Regular Infantry​
Generic Wizards:
(Cast 9+. A Lvl 1 wizard should use ~3 dice or 2 with a Hierotitan nearby. A lvl 2-4 should use use 2 dice for max efficiency)
A generic wizard can summon with 50pts:
- A Unit of 10 Skeleton Warriors with light armor (VC & TK) or 12 Skeleton Warriors without armor (TK).
* Spending 1 Counter, summon a Unit of 20 Zombies.
* Spending 1 Counter, summon a Unit of 10 Skeleton Archers.
Arkhan, Mortarch of Sacrament
(cast 9+, needs 2-dice)
Arkhan can summon with 100pts:
- A Unit of 20 Skeleton Warriors.
- A Unit of 33 Zombies.
- A Unit of 16 Skeleton Archers.
- A Unit of 10 Crypt Ghouls.
* Spending 1 Counter, summon a Unit of 10 Tomb Guard. Spending 2 Counters, you'll have 10 Tomb Guard with halberds.
* Spending 1 Counter, summon a Unit of 10 Grave Guard with our without great weapons.
* Spending 3 Counters, summon a Unit of 3 Cairn Wraiths.
Nagash, Supreme Lord of the Undead
Nagash can summon with 150pts:
- A Unit of 30 Skeleton Warriors, or a few less, but with full command and a magical banner.
- A Unit of 50 Zombies.
- A Unit of 25 Skeleton Archers.
- A Unit of 15 Crypt Ghouls.
- A Unit of 13 Tomb Guard, or 11 models with halberds.
- A Unit of 13 Grave Guard with great weapons.
- A Unit of 3 Cairn Wraiths. Spend 1 Raise the Dead counters to upgrade a Wraith to a Banshee.
Mid Version, Normal infantry
Generic Wizards:
(Cast 14+, lvl 1 - 3 wizards should use 4 dice, even with a Hierotitan nearby. Lvl 4 wizards can risk 3 dice, but are safer with a Hierotitan nearby.)
A generic wizard can summon with 100pts:
- A unit of 33 Zombies.
- A unit of 16 Skeleton Archers.
* Spending 1 Counter, summon a Unit of 10 Tomb Guard without upgrades.
* Spending 1 Counter, summon a Unit of 10 Grave Guard without upgrades.
(cast 14+, can 3-dice it, but it's safer with a Hierotitan nearby.)
Arkhan can summon with 200pts:
- A Unit of 40 Skeleton Warriors, or a few less, but with full Command and a magical banner.
- A Unit of 66 Zombies.
- A Unit of 33 Skeleton Archers.
- A Unit of 20 Crypt Ghouls.
- A Unit of 15 Tomb Guard with halberds.
- A Unit of 16 Grave Guard with great weapons.
- A Unit of 4 Cairn Wraiths, or 3 with a Banshee upgrade. Spend 2 Raise the Dead counters to summon 3 Wraiths and 1 Banshee.
(cast 14+, you can 3-dice it to preserve efficiency and more so with a Hierotitan nearby.)
Nagash can summon with 300pts:
- A Unit of 60 Skeleton Warriors.
- A Unit of 100 Zombies.
- A Unit of 50 Skeleton Archers.
- A Unit of 30 Crypt Ghouls.
- A Unit of 23 Tomb Guard with halberds.
- A Unit of 25 Grave Guard with great weapons.
- A Unit of 6 Cairn Wraiths, or 5 Wraiths and a Banshee. Spend 1 Raise the Dead counter to summon 6 Wraiths and a Banshee.
Buffed Version, Monstruous Infantry
Generic Wizards:
(Cast 16+, lvl 1-2 Wizards should only cast this with 4-5 dice and a Hierotitan support. Lvl 3-4 Wizards can use 4 dice but would be better off with Hierotitan support.)
A generic wizard can summon with 150pts:
- A Unit of 3 Ushabtis.
- A Unit of 3 Crypt Horrors. Spend 1 Raise the Dead counter to summon 4 Crypt Horrors.
- A Unit of 3 Vargheists with Vargoyle.
* Spending 1 Counter, summon a Unit of 2 Morghast Harbingers.
(cast 16+, needs 4 dice, but safer with Hierotitan support)
Arkhan can summon with 300pts:
- A Unit of 6 Ushabtis.
- A Unit of 7 Crypt Horrors with a Haunter upgrade. Spend 1 Raise the Dead counter to summon 8 Crypt Horrors with a Haunter upgrade.
- A unit of 6 Vargheists with a Vargoyle upgrade. (no need to spend extra Raise the Dead counters here)
- A Unit of 3 Morghast Harbingers. Spend 1 Raise the Dead counter to summon 4 Morghast Harbingers.
- A Unit of 3 Morghast Archai. (no need to spend extra Raise the Dead counters here)
(cast 16+, you can 3-dice this spell only with a Hierotitan support. A bit risky but very cost-efficient)
Nagash can summon with 450pts:
- A Unit of 9 Ushabtis.
- A Unit of 11 Crypt Horrors with a Haunter upgrade. Spend 1 Raise the Dead counter to summon 12 Crypt Horrors with a Haunter upgrade.
- A Unit of 9 Vargheists with a Vargoyle upgrade. Spend 1 Raise the Dead counter to summon 10 Vargheists with a Vargoyle upgrade.
- A Unit of 5 Morghast Harbingers. Spend 1 Raise the Dead counter to summon 6 Morghast Habingers.
- A Unit of 5 Morghast Archai. (no need to spend extra Raise the Dead counters here)
Razkhar - The Abyssal Swarm
Basic Version, War Beasts or Swarms
Generic Wizards:
(Cast 10+, Lvl 1-2 Wizards should use 3 dice for this spell. Lvl 3-4 Wizards can 2-dice it for better efficiency)
A generic wizard can summon 75pts:
- A Unit of 3 Nehekaran Vultures
* Spending a Counter, summon a Unit of 2 Tomb Swarms(?)
- A Unit of 9 Dire Wolves
- A Unit of 2 Bat Swarms
- A Unit of 4 Fell Bats. Spend 1 Raise the Dead counter to summon 5 Fell Bats
- A Unit of 1 Spirit Host. Spend 2 Raise the Dead counters to summon 2 Spirit Hosts.
(cast 10+, needs 2-dice)
Arkhan can summon 150pts:
- A Unit of 6 Nehekaran Vultures. Spend 1 Raise the Dead counter to summon 7 Nehekaran Vultures.
- A Unit of 3 Tomb Swarms(?). Spend 1 Raise the Dead counter to summon 4 Tomb Swarms.
- A Unit of 18 Dire Wolves.
- A Unit of 4 Bat Swarms.
- A Unit of 9 Fell Bats. Spend 1 Raise the Dead counters to summon 10 Fell Bats.
- A Unit of 3 Spirit Hosts.
Nagash can summon 225pts:
- A Unit of 9 Nehekaran Vultures. Spend 1 Raise the Dead counter to summon 10 Nehekaran Vultures.
- A Unit of 5 Tomb Swarms(?). Spend 1 Raise the Dead counter to summon 6 Tomb Swarms.
- A Unit of 28 Dire Wolves.
- A Unit of 6 Bat Swarms. Spend 1 Raise the Dead counter to summon 7 Bat Swarms.
- A Unit of 14 Fell Bats.
- A Unit of 5 Spirit Hosts.
Buffed Version, Monstruous Beasts
Generic Wizards:
- A Unit of 1 Scorpion Golem (this Unit cannot be increased beyond 1 model, so this is what you'll get with a standard cast).
* Spending 2 Counters, summon a unit of 3 Sepulchral Stalkers.
- A Unit of 1 Scorpion Golem (this Unit cannot be increased beyond 1 model, so this is what you'll get with a standard cast and is overkill with Arkhan).
- A Unit of 5 Sepulchral Stalkers.
- A Unit of 1 Scorpion Golem (this Unit cannot be increased beyond 1 model, so this is what you'll get with a standard cast and is overkill with Nagash).
- A Unit of 8 Sepulchral Stalkers.
Reactions: BloodbathMcGrath
Kandorak - The Harbinger
This spell should only be used by Lvl 3+ Wizards, as it has the highest casting value of all spells from Undeath, specially the buffed version.
Basic Version, a single Character.
Generic Wizards:
(Cast 10+, you should 2-dice it for better efficiency)
A generic wizard can summon 65pts:
- A Sepulchral Herald, with mundane upgrades, usually a great weapon or a flail. Spend a Raise the Dead counter to give him a Skeletal Steed.
- A Necrotect with 5pts magical item.
* Spending a Counter, summon a Tomb Priest
- An unupgraded Necromancer
- A Cairn Wraith.
Arkhan can summon 130pts:
- A Sepulchral Herald with 70pts left for upgrades.
- A Necrotect with every upgrade you can give from his magical items allowance.
- A Tomb Priest, with 60pts left for upgrades.
- A Tomb Prince with 30pts left for upgrades.
- Prince Apophas
- A Necromancer with 65pts left for upgrades. Spend 2 Raise the Dead counters to give him a Corpse Cart as a mount.
- A Cairn Wraith (can't purchase 2, because you can only summon a single character)
- A Tomb Banshee
- A Wight King with 45pts left for upgrades.
- A Vampire with 25pts left for upgrades.
Nagash can summon 195pts:
- A Sepulchral Herald with every upgrade you can give him.
- A Necrotect with every upgrade you can give him.
- A Tomb Priest, with every upgrade you can give him.
- A Tomb Prince with 95pts left for upgrades.
- A Tomb High Priest with 20pts left for upgrades.
- A Tomb King with 25pts left for upgrades.
- Prince Apophas
- A Necromancer with most of his upgrades, including a Corpse Cart, extra magic level or magical items.
- A Tomb Banshee
- A Wight King with every upgrade you can give him.
- A Vampire with 90pts left for upgrades.
- A Master Necromancer, with 30pts left for upgrades.
* Spending a Counter, summon a Vampire Lord with 5 pts left for upgrades
* Spending 2 Counters, summon Krell, Mortarch of Despair.
Buffed Version, a single Monster, Chariot or War Machine.
Generic Wizards:
(Cast 24+, 6-dice this spell, it's a must. Hope you don't get swallowed by a Dimentional Cascade =S)
A generic wizard can summon 200pts:
* Spending 1 Counter, summon an unupgraded Warsphinx of Khemri
- A Necrolit Colossus with any upgrade you want to give it.
- A Hierotitan ( if you didn't have one already, shame on you! D: )
* Spending 3 Counters, summon an unupgraded Necrosphinx
- A Screaming Skull Catapult with any upgrades.
- A Casket of Souls
- A Corpse Cart with any upgrades.
- A Black Coach (yay!)
- A Varghulf
* Spend 2 Counters, summon an unupgraded Mortis Engine
* Spend 3 Counters, summon an unupgraded Terrorgheist for the best fun ever!
(Cast 24+, 6-dice this spell, it's a must. Hope you don't get swallowed by a Dimentional Cascade =S. If you need to, have him use his extra 2 dice stored from his staff, only if you're desperate)
Arkhan can summon 400pts:
- A Warsphinx of Khemri with any upgrades.
- A Necrosphinx with any upgrades.
- A Casket of Souls
- A Varghulf
- A Mortis Engine with any upgrades. Now you can have 4+ Regen Saves for all!!
- A Terrorgheist with any upgrades for the best fun ever!
***Since it is not clear if one can also summon Monster Characters, like Mortarchs, or upgrade Characters with Monster or Chariot mounts, those are not included here.
(Cast 24+, 6-dice this spell, it's a must. Hope you don't get swallowed by a Dimentional Cascade =S. Also, you may want to use his 4 extra dice to have this spell almost guaranteed IF)
Nagash can summon 600pts:
- A Casket of Souls
- A Varghulf
***Since it is not clear if one can also summon Monster Characters, like Mortarchs, or upgrade Characters with Monster or Chariot mounts, those are not included here, but they should, considering how many points Nagash can summon, but those spent are at most roughly 30% of his allowance.
Akar'aran - The Dark Riders
Since this is a spell that can change the game by summoning heavy cavalry in the Special / Rare slots of the Undead Legions, you save up your Raise the Dead counters for either this, or Kandorak's Monsters. Feel free to save as many counters here as you wish, in order to summon a very powerful Unit and wipe those who would oppose you!
Cavalry, Monstruous Cavalry and Chariot Units.
Generic Wizards:
- A Unit of 5-12 Skeletal Riders.
- A Unit of 5-10 Skeletal Archer Riders(?) with 10pts left for upgrades.
* Spending 2 Counters, summon an unupgraded Unit of 3 War Chariots.
* Spending 5 Counters, summon an unupgraded Unit of 3 Necropolis Knights.
- A Corpse Cart with any upgrades available (since it says Chariots, that includes 1 chariot, of course!).
- A Unit of 5-7 Black Knights, with upgrades. 5 Black Knights with barding/lances and 20pts left for upgrades.
- A Unit of 5 Hexwraiths, but no points left for the Hellwraith.
* Spending 5 Counters, summon a unit of 4 Blood Knights, unupgraded but ready to kick some ass!
* Spending 5 Counters, summon a Black Coach... because Kandorak is not enough!! (since it says Chariots, that includes 1 chariot, of course! Need to confirm this!).
* Spending 7 Counters, summon a Mortis Engine (since it says Chariots, that includes 1 chariot, of course! Need to confirm this!).
- A Unit of 5-25 Skeletal Riders, with most of their upgrades.
- A Unit of 5-21 Skeletal Archer Riders(?), with most/all of their Upgrades.
- A Unit of 3-5 War Chariots, with some/most of their upgrades.
- A Unit of 3-4 Necropolis Knights with some/most of their upgrades.
- A Unit of 5-14 Black Knights, with upgrades. That is 10 Black Knights with barding, lances and full command, but only 10pts left for a magical banner. Spend 1 Raise the Dead counter to have the unit carry the Banner of the Barrows and the Standard Bearer, and 2 Counters to have all upgrades.
- A Unit of 10 Hexwraiths!, or 9 + a Hellwraith (Arkhan hits the sweet spot of the max Unit size of Hexwraiths).
- A Unit of 4 Blood Knights, with Musician, Standard bearer and Flag of Blood Keep. Or 6 Knights unupgraded, or 5 with full command and a 15pts magical weapon for the Kastellan, etc.
- A Black Coach (since it says Chariots, that includes 1 chariot, of course! Need to confirm this!)
- A Mortis Engine, with all upgrades (since it says Chariots, that includes 1 chariot, of course! Need to confirm this!).
- A Unit of 5-37 Skeletal Riders, with any of their upgrades.
- A Unit of 5-32 Skeletal Archer Riders(?), with any of their Upgrades.
- A Unit of 3-8 War Chariots, with some/most of their upgrades.
- A Unit of 3-6 Necropolis Knights with some/most of their upgrades.
- A Unit of 5-21 Black Knights, with upgrades. That is 14 Black Knights with all upgrades and Banner of the Barrows, or 15 Knights with barding/lances, Standard Bearer and Banner of the Barrows, etc.
- A Unit of 10 Hexwraiths with a Hellwraith (max Unit size is 10, so this Unit is kinda wasted on Nagash, but by no means useless)
- A Unit of 7 Blood Knights, with Musician, Standard bearer and Flag of Blood Keep. Or 9 Knights unupgraded, etc.
Thanks for starting this, I have been working on a similar project as well. One thing i noticed is tomb scorpions are counted as a unit of 1, so multiples cannot be summoned reguardless of the points limit. Unless somone can prove me otherwise.(hopefully they can )
Max size for a unit of Hexwraiths is 10
Holy crap, the trouble this saves me! Thanks so much, this is much easier than flipping through my book every spell I cast. I vote for a sticky :)
One of my favorite vampires to summon with nagash is vampire with red fury and either ogre blade or swor of strife.
He's naked and Killy.
Also if you spend 3 tokens with nagash you can get a ghoul king with 25 points if items.
This has made me want to get nagash even more.. All those summoning options.... Need to save up some money and buy him I think.
Quick question : while summoning, do i have to follow the minimum number of models in a unit ? it's not clear in the rules :(
Yes, you must follow all the rules for minimum (like 20+ zombies) and maximum (like Hexwraiths), that's why some Units are not available unless you spend some Raise the Dead counters first (like a unit of Cairn Wraiths)
Very nice summary Demian I love it and will certainly bring this to future games!
I have been considering bringing Nagash. As for the games I've seen he has been able to summon for at least somewhere in between 500-800 points worth of models per game.
Given that he is also a very good at killing stuff himself (beating a unit of skullcrushers, I think they're called? The WoC cavalry juggernauts that everyone seems to avoid apart from our Tgheists) all on his own.
Looking at all those nasty things he can bring to the table.. Well, it just makes me want to run off to the store and buy him.
I have a PDF created which is basically a copy/paste from his notes. If someone gives me a place to upload it, I will share it.
EDIT: It is 10 pages long, and I spaced out the spells and some of the sections to give it some better readability at the table.
Nagash Book 2 on the page opposite the spell list in the box titled summoning spells it explicitly states that you must adhere to minimum unit sizes etc
Considerations when playing:
Arkhan, Mortarch of Sacrament:
  • He is a Lvl 4 Wizard, that only knows spells from the lore of Death and Undeath, he has no access to healing, other than Breath of Darkness, his own Tomb Blade and Feaster of Souls in combat. You can go full Death magic with Ryze (signature spell) and use all debuffs you can get and maybe Soul Leech (but since he has Ld 9 and can't have Standard of Discipline, he may not be as effective as a Vampire for that...) hopefully, you get any other spells, excluding Dreadknight and you're set.
  • He is best played with full Lore of Undeath, since his Soul Leech is not that powerful, and his summoning is much better than a regular wizard.
  • Be careful with Khenash-an, the Staff of Spirits, since it will Not allow you to store dice from or for your Dispel Pool, only your Power pool (during your own turn), and can Only use such stored dice in your next Magic Phase (not on your opponent's for dispel purposes, as the Black Periapt does). Therefore, plan your Next magic phase to cast your most threatening spell with 8 dice if you wish, or cast his 4 spells with low dice, as provided in this guide, to maximize efficiency: (ie: once Arkhan is near your target as he can fly, you use Kandorak to summon a Terrorgheist that can scream that very same turn, since it is close to his intended target. Worry about the miscast later!).
  • In order to maximize his special rules, cast your not-so-threatening Undeath spells to harvest some Raise the Dead counters, maybe Breath of Darkness to get some Morghasts into position, etc, but plan ahead to leave 2 dice untouched to store in his staff. If you get dispelled a lot, then consider using those 2 dice right there to get a spell off without resistance, or... store them and may your next magic phase is better used. If you get a poor phase, or you simply see your opponent is saving his dice and will not let your last spell go off, then close that phase and store your dice, leaving his dispel pool to waste. Repeat until you have the amount you want and the time is right to use your spell.
  • Don't underestimate Sulekhim - The Hand of Dust on him, since (by the poor wording of the spell), does NOT end once cast (nor until your next Magic Phase) and can't be dispelled later on the game (since it is not a RiP spell). This will give Arkhan the combat leverage he needs to destroy much scarier things, and draw some dispel dice or generate a Raise the Dead counter!
  • He should not be out of combat the whole game! The closer he is to your target, the better used his summoning will be (and Death magic if you choose to use it). He can easily best Core troops, and can take on stuff such as Bloodletters (because of his T6 and immunity to Killing Blow) and Nurgle troops (Thunderstomp if he fails with his WS4).
  • Don't worry about some wounds, say... elves may inflict upon him with his Ini 3, that's how he heals, after getting beat.
  • He can also take on Cavalry if you're skilled, even if he has Str 5, he can counter Instability with his own First of the Mortarchs and maybe a Morghast guard nearby (cavalry is usually Str 4).
  • He must get into combat in order to heal, but can't take on Special or Rares by himself. Anything with Str 4 or less will struggle to wound him! He is not an empire wizard, but an Undead, so get him into combat!
Was wondering what has worked out for you guys more.
Using arkhan or nagash ?
It seems like nagash is always a bit over the top with his summoning whilest arkhan hits most of the sweet unit sizes for most options.
Apologize if is a stupid question,I'm in a hurry writing a list. Magical object are considered upgrade when summoning characters?
Yes, Magical objects are upgrades to characters!
And about Arkhan or Nagash.. I don't have a definitive answer to that, but I'd lean over Nagash because of his triple summoning range and better combat stats. With Arkhan, you'd need to also purchase a killy V. Lord / SGK to compensate, and that isn't always bad, mind you.
Reactions: Emicrania
