XV42 Hurricane Battlesuit - Conversion & datasheet finished
Count Darvaleth
I <3 marmite
3,407
Before any of you Tau-enthusiasts get over-excited, I just wanted to say that you can go for it, cause I'm excited too. xD
I have set out to do the impossible; I hope to convert a Grey Knight dreadknight into a Tau super-ultimate battlesuit. I'll say that again so it settles in.
There are no pictures/WIP because I haven't started. This conversion is still in the design stage, however, I plan to buy the dreadknight and a normal XV8 crisis suit, and replace the funny grey knight cockpit with the tau battlesuit. I'd get rid of his legs, but have his arms and head, perhaps.
Anyway, I'm asking for advice from you guys. Are there any bits I should look to grab? Which weapons should I use? I have a wealth of imperial weaponry lying around, and a few small Tau support-weapons, but nothing big enough to be the Tau main weapon. Any ideas? And how do you think I should put the cockpit in there?
I think I have a Broadside railgun lying around also (don't ask how) but it's half-stuck to something. I'm gonna go and prize it off now, but any suggestions or comments, please post. Thank you for your time.
Count Darvaleth
EDIT: It seems I already removed the railgun, so that's all good. And also I noticed the Dreadknight is only £33 (I was expecting something closer to £60!) so my budget for bits has just gone up (I can now actually afford the Crisis suit!). This is good.
RE: XV42 Hurricane Battlesuit... Tau Dreadknight Conversion
I think alot of plasticard panneling to make the bits look tau.
Also consider using bits of vehicles.
Sorry for double post, but look at this guy...
and this guy
SOOOOOOOOOOOOOOOOOOOOOOOOOOOOO COOL!! You can do better though C Darv. I second Sanai, get a load of Plasticard. Also seeing as your budget went up considerably and thinking about the limitations of a Crisis suit, the purchase of a piranah or better yet a Hammerhead or Skyray gunship might help more with your endevour (not to mention all the cool bits you'll get!!)
Very much looking forward to seeing what you come up with.:zombie:
Ion cannon and Railgun arms with maybe a Skyray battery on his back?
Santawraith said:
This belongs in the dead space forum
Am I not asking for modelling advice? I didn't know the Hobby section was fantasy only. Meh.
Unfortunately my modelling skills aren't entirely super... I have some sheets of plasticard lying around somewhere, but what would I do with them? Cut and use to "Tau-ify" army plating? Like instead of all curved and round, make them more flat and rectangular, with the scored lines on them as well?
As for buying vehicles, my budget isn't that big. xD I would need the crisis to make the cockpit look proper, then I could use bits to Tau-ify the rest.
Ah yes, upon checking my poor bank account (yay telephone banking) it seems that buying the Tau Codex, Battlesuit commander and fire warrior box has hurt me a lot more than anticipated... so the limit for what I can get is £55. SO, minus the dreadknight and crisis suit, I've got, erm, £8.20?
EDIT: If anyone could point me towards a good plasticard armour-plating tutorial, that'd be very kind.
Ok, update time. My brother lost the plasticard, but I found some rather interesting Valkeyrie missile pods...
Oh, and the conversion is done. Really quite easy, and for somebody who has never ever done anything more than a head-swap (and that was ambitious) in terms of conversion, I'm pretty proud of it. It really was simple, you should give it a go. Anyway, here are some crappy blurry pictures; but when he's painted, I may be able to get a proper picture (to paste into the datasheet) by using somebody's camera.
Hope you like them. Any comments/questions, please feel free to post them up. ;)
EDIT: Here's the datasheet for the XV42 Hurricane Battlesuit also. Enjoy!
XV42 Hurricane Battlesuit Commander
WS....BS....S...T...W...I...A...Ld...Sv
3.......5......6...7...6...3...2...10...2+
The Ethereal Caste and Earth Caste have been working together for many years to develop this new battlesuit. Whilst it is still not ready for mass-production, it is currently under-going full field-testing in major conflicts across the Third Sphere expansion area. It’s new, experimental teleportation device coupled with its dazzling array of weaponry have already made this battlesuit destined for full mass-production and distribution amongst the Fire Caste’s elite.
Character: The XV42 Commander takes up one HQ choice and can only be fielded in a Tau Empire arm, is an independent character, and cannot join units. The XV42 must be taken exactly as it is presented here, and cannot be given any additional upgrades.
Equipment: XV42 Hurricane Battlesuit, shield generator, XV42 railgun, XV42 multi-tracker, two twin-linked smart-missile systems (which have an extended range of 36”), and a Gatling Ion Cannon.
Unit Type: Jump Infantry (jet pack).
SPECIAL RULES
Hurricane Battlesuit: The special-issue Hurricane suit grants the bearer the Relentless special rule. In addition, the hard-wired Hurricane teleporter makes the wearer Jump Infantry (jet pack) and gives him the Hit and Run special rule; however, no Iniative test is required to use the Hit and Run rule, but the XV42 will only move 2D6” away from combat instead of the full 3D6”.
XV42 Railgun: This railgun can fire using the solid shot or submunition round, like a Hammerhead railgun, as detailed in Codex: Tau Empire. It also counts as twin-linked.
XV42 Multi-tracker: This specially designed multi-tracker allows the user to fire all weapon systems each turn.
Gatling Ion Cannon: The XV42 battlesuit is armed with a colossal special-issue weapon, originally designed for use on vehicles and aircraft. The weapon system uses the following profile:
Weapon.....................Range.....Str.....AP......Type
Gatling Ion Cannon.......36”..........5.......3.......Heavy 10, twin-linked
Lovely stuff, it looks awesome. Like one of the big Japanese Mechs! I was a little unsure of just how successful it would be but you have quashed my uncertainties! I can't wait to see it painted now!
Cheers,
u_m
Thanks UM! I too was thinking, as I spent £50 on the things needed, "what if it all goes wrong?!" but thankfully it worked out.
I was sorta doubtful when I chucked the missile pods on the top, but then thought: what the hell, they're just another set of huge guns!
I'm not sure how to paint it, though. My original plan of spraying models black, then dusting white, then inking/washing has failed rather miserably, so I need a new colour scheme... I'm going to hunt for an easy one. xD
Those missile pods are ginormous. Perhaps you should replace them with a pair of racks of hammerhead missile pods.
I did think they were pretty big (I even put regular Crisis pods on top of them!) but I had no alternative, really.
Perhaps I'll make another one day when I have more cash available and buy some vehicle models to use parts for. But other than his bulbous missile pods, which I can live with really, I'm fairly pleased.
At the moment, everything 40k belongs in the general Dead Space forum. This is a another change that we are working on for the new site.
Ah, ok. I look forward to the super-duper upgrades then. (Equality for 40k and fantasy Movement! Hurrah!).
I suppose it does't matter where it lives, as long as it's not hidden away in the dead section of User projects. xD
EDIT: Looking again at those pictures, they do make the missile pods seem rather huge. In reality, they don't dominate the model quite as much as you see here!
Vekarin the Dark Bladed said:
P.S. In those rules, would it not be more appropriate to label the unit as a Monstrous Creature rather than a 'weird-Independent-Character-who-can't-join-units-dude-thingy'?
Well, I didn't want him joining units of battlesuits, but if he was a MC then he'd ignore armour saves and do 2D6 armour pen, and he wouldn't be jump infantry... things would get confusing. He's just a big battlesuit.
If I ever make another, then they could make on uber-unit, but I wouldn't see the need for something so big. I've tested it and it's not too over-powered; it'll much its way through a unit of SM, sure, but not with tonnes of wounds to spare. It can't shoot at a unit of 50 ad expect to kill them all. I was thinking it'd be around 350pts.
EDIT: Oh yes, I had seen the link already. I did my research! :tongue:
You could make it a Monstrous Creature that moves like Jump Infantry like the original Dreadknight that you made it out of!
Battlesuits are supposed to be very powerful on their own - I mean, a lowly Crisis suit is Strength 5!
Just my .2 $ US, but it's your call, you are the creator, after all! xD
I don't want to encourage people to send it into combat; with being able to escape at will and have a blistering amount of firepower that can be shot even when assaulting, I think ignoring armour saves (thus AP1) and causing 2D6 armour pen will tempt me to use it overly aggressively.
Perhaps it's a little bit weird, but then I'm no professional rules-writer. ;)
I was going to post that guy for Count Darvaleth but He had already uploaded his finished pictures so i rejected that course of action. But what a wonderful and simplistic daemon prince conversion eh?
I saw that too. I feel the left arm is a little small, but that's a nitpick. Very nice model I say, if I ever make Chaos Marines I'd go all techy and get myself some Soul Grinders, Dreadknights, DPs, and have a party. xD
Oooh, this has really really REALLY got me itching to do some start collecting some Tau. I think I will have to see if anyone is interested in swapping any for the unused Tyranid's that are laying under my bed.
Great work Darvy, especially if you haven't done a big conversion before :thumbsup:
Too much in that quote is pervertible. xD But thank you anyway. The Tau are certainly a unique army, and this conversion was surprisingly easy. I'm honestly amazed I didn't totally fudge it, having never done any modelling of note beforehand. Give it a go. All you need is green stuff, plastic glue, and...erm... that's it. :tongue:
But if you really liked it you'd get on with the super-duper forum upgrades...
EDIT: The mods made me 91 whilst you were away. I knew it could only lead to trouble...
They made you 91, good good, they are still following my orders to annoy you xd
The upgrades might be complete shortly, I complained today so they said they will have the theme done by Wednesday.
But, but... but! :slapface:
Good job on the complaint. We British do rather excel at that (although I have often wished I was born German, because all the good composers were German and I can't understand their choral works... :( )
EDIT: I suppose you can lock this thread now. But do try not to fail like MS did earlier (it was brilliant, see the "what is the lance rule" thread!)
