2 Hell Blasters and a Banishment Party? WTF?
Is the 36 S7 hits a way of speach or is it the actual results? Sorry for knitpicking, but only the popemobile gets S7 given there were 3light mages. The lvl 4 cannot count himself towards the strength of his own banishment and the altar is not a wizard, so his spell is resolved at S6. Also 36 banishment hits in one magic phase is called a yatzi. Like 0, 002% chance. But the BK's would have had a hard time even against the expected hits: 10.5 S7hits and 10.5 S6hits =17.5 wounds before saves.
In a rematch I would like to join the mounted vamps with the 40 skeletons, after hexwraiths have made contact with the stank, until the coven threat is dealt with. If neccecary sacrificing the BK's in the prosess
how did the vargheists fare? It's always a downer to loose on bad rolls, but atleast you know your game plan worked. And in addition the empire list you faced is a really bad matchup for most VC lists IMO.
Best of luck with the remaining battles, raven :-)
It was 36 hits. 2x triple 6. Both were cast with IF. Nothing bad happened to his level 4. He swapped dice between rolls, unfortunately I rolled the same dice after to check if they were loaded, lol. Rolled triple 1 (of course).
The vargheists have been thoroughly lousy or more accurately, my rolls were lousy. 17 attacks, 2 hit. Nuff said. Demigryphs killed them the turn I charged (frenzy's a bitch). I was lined up to hit his council bunker when I failed their ld test. I think that was the only time I rolled high numbers.
Wow! That is bad dice!! Too bad about the vargheists. If they had just made that charge, things could have been alot different. Have you tried the charge blocker with the vgheists? If you put dwolves in beteeen the closest enemy and the vgheists, you can choose to charge on foot, automatically failing because of dwolves blocking ground movement:-)
If you do use charge block tactics, watch out for people arguing the finer points of the rules, or being called a rules lawyer. I would never do t myself, because the 'spirit of the game' and in reality would a blood-driven Vargheist decide not to use its wings and not charge the nearest?
I agree with you Vashra, both congassassin, moonwalk and chargeblocker mechanics are gamey. Personally, it is easier for me to accept that another VC unit helps to subdue the VG's bloodthirst, than seeing them make a last minute reform on the battlefield willingly turning their backs to the blodbags.
