Alamo GT Army 2500 Points
Ogre said:
DBG is on the SGK. He decapitiated a baby vampire from the newest list :)
Then charmed shield (discard first hit) or Dragonhelm. :thumbsup: Empire cannons were deadly and numerous at QCR. There were not many Dwarf players.
They changed 'Look Out Sir' with 8th. Use to be a Vamp lord could join 4 or 5 Blood knights and be good to go. Now he can be snipered with cannons. One of the reasons BK buses have to be 10+.
I found a big problem for my army when I played a 2nd game..... Wood Elves Tree Spirits.
Treemen Ancients at Tough 8 are just incredibly hard to wound, even with a SGK. Everything else in the army needs a 6 to wound the Giant tree.
Plus the high toughness on Treekin posed a significant problem. The only way I see to deal with those easily are....Terrorgheists...
I don think Im likely to run into this config at a GT anyways, which means the only HUGE threat comes from Ogres running the Lore of Beasts to turn the butcher into a Mountain Chimera....
I never got Trans of Kadon off a single time last week. It is darn hard to roll 20 for that Mountain Chimera. Plus wounds carry over so you might die as soon as the spell is dispelled.
Wood Elves are rare at tourneys. The ones that are more successful are the all cav run from you type. I would not sweat Wood Elves.
Ogre players can get Transformation off with the Gutsickle and a few other things giving them plusses. Typically the spell only goes off on a Miscast, at which point who cares about the miscast. The Ogres now have a Mountain Chimera(ZOMG!)
I dropped the 2 Bat Swarms and the Dreadknight on the SGK and was able to pick up a Wight King BSB with The Banner of Eternal Flame. Im not sure how I feel about that as having the swarms around was handy(turn 2 charge a cannon, and charging fleeing troops.)
So Ill try this out in a week or so as I dont know when Ill be able to play again for bit since I have my Security+ exam next week.
Wood Elves are a bad matchup for us. Just remember to keep pressure on his core Archers and scouts and you'll be good. The Treekin I am surprised they gave you trouble. They always run on me. Hit them with the bus and they will do very little in a game and avoid them getting in your flank. I usually try to keep myself into a tight ball Until I'm ready to destroy them. They really can't do crap vs our healing and large numbers.
I had the unfortunate displeasure of playing "Battle for the Pass" so there was not much maneuver room on the board which totally hozed my armies stratey(ghouls and GG engage the front while BKs come in the flank to save the day.)
So maybe in a standard deployment I can get better match ups.
Come on, guys, it's fricking Wood Elves. As a far more experienced Wood Elf general than a vampire one, I can guarantee you that by far the two worst match-ups for WE are VC and DoC, as both don't flee, and WE suck at proteracted combat.
WE suck at proteracted combats, and when they can't multicharge. Which are both easy to make happen when playing VC, even more so in battle of the pass! Deploy very very wide is my most important advice (e.g. 15*2 Grave Guard, 15*3 Ghouls, 25*2 Zombies,...), Wood Elves can't break through our lines, which effectively renders their cav and skirmishers useless.
The big trees are easily killed by a largish (20 should do) unit of Great Weapon Grave Guard; a (flaming) ghoul unit, a terrorgheist; a blood knight unit, literally anything flaming. Heck, skeletons will when buffed do some wounds!
Just don't run a SGK. he hasn't gotten enough armour save, so the typical Wood Elf assasins (snipers,...) will easily be able to kill him. Armour your lord, or keep him out of combat ;)
What I *really* think was happening was it was his second game with Wood Elves so I think I was being cheated inadvertently. Otherwise I think my SGK would have felled the Treeman Ancient...
Annoyance of Netlings. The treeman ancient should have been able to kill a couple of SGK's, if it was in a challenge. Although an ancient does have T6, rather than the T8 you posted above. But if he did challenge, your SGK should have refused, in which case he'd have been useless, or if he accepted, he wouldn't have been able to hit it efficently, let alone kill it ;) so he might have had his rules wrong, but TMA still >>> SGK.
He didnt have annoyance of nettling s. Wow I got screwed. Treeman Ancient should have been kindling....
I think the only T8 thing in the game at the moment is Warsphinx and the other build for the sphinx.
Just for fun I was tinkering with the list. I dropped the BKs, Dropped the Wight King BSB, and picked up 2 Terrorgheist. I think Im going to test that config out. But at this point I dont have a 2nd Terrorgheist.
personaly i would try to stay away from mounting any lord in games bigger than 2200. Artillary is way to hot in 8th ed, and there is too many reroll the misfire ablity out there. Yes you want the vampire to destroy things. But pros and cons.
I´ve played quite a few games with my cavbus lists and some things I´ve learned:
- A level 4 vamp lord really needs the earthing rod. Sword of might still gives him S6 and talisman of preservation is a must. You simply cant lose your general to a miscast.
- Terrorgheists will be eating cannonballs, but hopefully the bus gets into combat. Which leads me to...
- The terror bomb, very effective. -1 ld taken on 3d6 with re-rolls to successful tests. Even dwarfs will fail eventually. Biggest threat are organ guns. If he brings 2 organ guns, cannons and stone throwers...you´re screwed :D.
- I´d prefer the vargheists over varghulf (even though I can see the varghulfs merits too) simply because a cannon cant one shot them to death.
Another thought I´ve had is to test a master necro list. GG, crypt horrors, ghouls etc will hit hard with the proper magic support.
Vampires have a pretty hard time vs shooty armies and I think a master necro list would be best vs those opponents. IoN spam will keep the army going.
Ive played a few games with this list now. What has made the difference for me is AoDM. And the fact that Im using Overlapping fields of it has been a shock to my opponent. I deploy the SGK on the corner closest to the black knights, and the black knights deploy approxamtely 6-12" away from the SGK side to get into flanks.
-2 to leadership is enough to bring dwarf leadership down to managable. But, by adding the Shadow spell that makes a unit -3 Ld, you now have a cumulative -5. Most units at that point will need insane courage to stay if you win by even one.
If I had the points for a Coven Throne, I would use it in this list. But As is, this list gets down and dirty. All the games Ive played with it have been a real slobberknocker with the dust clearing at the end of 6 for winner.
