Bishop (DE) vs Wolf Fang (Sk) - 2400 pts
Status
Passed.
Charges:
- Clanrats with Screaming Bell charge the hydra.
- Stormvermin charge SPearmen unit 2.
- Rat Ogres 1 charges Crossbow unit 2.
Any charge reactions?
Screaming Bell unit charge distance. 7 needed in total so automatic completed charge. :)
Stormvermin need to move 10 inches so a roll of 5 on 2 dice needed.
Passed.
Ogres need 12 inch so 6 needed due to 6 inch normal movement. That is if they're not shot to bits.
And charge reactions are indeed before a charge is resolved. so shooting distance is measured to where the unit starts the charge.
Can't believe that I still have a pc without BC on it :D
Those ROs 12" less from the XBows? (I'm guessing, since you need a 12.. :D )
So, 20 shots -1 rep, -1 SnS needing 5s and 5s
Movement updated.
Am I allowed to move the Rat Ogres in base contact with the mage in the Crossbow unit?
I'll also roll for Winds of Magic while I'm at it.
Nothing good. Any friendly unit withing 24 inch can re-roll failed Ld tests untill my next turn.
I don't think so. Since you already have max models engaged.
The ROs need to roll river type, and then I think that they need a dangerous as well for charging through the river.
So 5 PD for me and 2 Dispell Dice for you. Not what I'd call my ideal magic phase, but here goes nothing.
I'll try Skitterleap with the Warlock Engineer first. Cast on 5+
1D6 +2
Cast on 20.
Unless you have some other form of Dispell scroll that's only going to be dispelled on double 6.
Status
