@Pirate Robot Ninja of Death,
CoY is a bit situational, only armies that field decent sized units are really scared of it and its usually dispelled with 3 dice on 12+ in their own magicphase. In the end, its often worth more to have a lesser magicphase yourself than have VC with VHDM. everybody knows that VC units suck balls until they get VHDM on them. If i as an opponent have the critical choice between letting CoY hit once or facing a 2x cc VHDM unit(s), its an easy choice.
This is my problem with VC every time, the one spell that actually makes combat really worthwhile and gives our units the upper hand or at least as good as what its facing gets dispelled 4/6 phases. the remaining times is when its cast at lesser critical moments.
Raise dead, yes its awesome but you will need to cast it more than once to make it gamewinning tbh. summoning 13 zombs once to redirect isnt gonna win you the game most of the time.
So if you play it with Raise dead, vhdm+IoN you want to cast 3 spells in a phase. one to lure a dispel and one you really want to have through. the third usually is a bonus. Its not so hard for a seasoned opponent to know which spell is the most dangerous to let through.
Problem being with all this? Is that unlike many other armies, we actually depend on the succesful magic to happen. Without it were a pretty noobish army, no IoN, no VHDM and no raise dead = a very big setback.
Ofc if youve done your movement very well you can mitigate damage done by failing magic but i find other armies, especially the toptier, to be much less depending on succesful magic. If they play their movement right, their normal units can just have a go at VC and win.
Other armies can just launch bolts/DD/hexes and whatnot to nuke your army and if that fails, well, their units still outclass ours in combat
Also, the larger points the game gets, the more VC suck since you dont get extra pdice to keep afloat or boost your units. playing above 3.5k is getting really bad.
