Dear Johnny
I just don't like their fluff. These are the final acts of a desperate vampire, brought on only if no other option will save them from defeat. Loathsome even to the most depraved vampires. That sort of thing turns me off to them.
Johnny-Crass said:
But they wound you on 4's and you have a 4+ regen
CH have a 5+ regen ;)
To add to Larry's points, being multi wound models, you usually can use our lore attribute on them too.
As for hammer units, grave guard with greatswords and if used right varghiests.
As for the viability of CHs, I had a 3x2 unit of them suck up a grail knight and errantry knight combo charge with a life damsel nested in the GKs. I let her cast throne and stone flesh knowing that poison was going to be the key. I held through combat for 3 full turns, staying raised and whittling down the knights. I had issues with the knights armor or I'd have destroyed them both. Made a huge mistake by sending in a unit of zombies with my vampire to support the horrors, which you should never combine tarpits in combat with other units, as the zombie casualties tanked the CR and crumbled the CHs. any other vampire unit that would dish out damage would have turned that stalemate into a solid victory.
But the point, roughly 230 points of super ghoul tied up half of a bretonnian army for over half the game and was doing fine.
Dear johnny (Its me again!!! suprrise!!)
Would you kindly explain to me how redirecting works? I can totally see how it works against units with frenzy but otherwise? You just put ur small unit in front of something so theyll have to charge it if they want the stuff behind it? Do you put your DWs just so you can charge a war machine next round so they are forced to charge em with something?
Im not sure so I would be grateful for a clarification!
You put a fast and cheap unit up as close as possible and at an angle so their only choice is to reform to avoid the unit or charge it. Because the charging unit closes the door into the charged unit, how you angle the unit affects the chargers overrun, thus causing them to either reform at the end of combat or overrun further from where the unit wanted to be.
With the last FAQ, this tactic got even stronger because you only overrun if you kill all the undead before combat resolution and crumble.
Dire wolves & fell bats work best as fast reliable redirectors. Single spirit host base can lock a unit down if it can't deal with ethereal. The raise dead spell is the best stealth redirector in the game. 20 man zombies work well too if you want to hold them their longer than a round as zombies tend to have a few survive through the crumble, thus allowing you to get an easy flank. Just make sure the zombies getting killed in the next round won't cause more crumble than your flanker will be able to counter through its damage and wounds it can take.
There is an art to getting good at redirecting. Try each option out and more than a few times, and you'll be redirecting with the best of them in no time.
Thank you!! It was kind of like I suspected but I just have a hard time seeing it in my head. So you put the DWs for example like 1 inch away from the unit you want to redirect, but at and angle which forces them to either charge the DWs or reform, if they want to move at all? Also that would mean you want another DW unit behind the first one since its going to get wiped out? otherwise they would just reform for free after that for destroying the whole unit no?
Your getting the idea! That is one option if you want to hold that unit in place. They may just choose to combat reform though. If you run five wolves 3 wide and 2 deep, all the wolves still fight and your guaranteed a crumble result instead of letting your opponent overrun.
Also, combat reform occurs before crumble. Since you can't remove models engaged from combat, your opponent can't do much with a reform, especially if thier command or characters are tied up.
I was hoping for a bit more wailing, gnashing of teeth, and rending of garments in the Athel Loren/Wild video, but at least the reviews themselves are solid. And as written, Bray-Scream can't be cast into combat (not a hex or augment), so you'll never be in a situation to use it in combat.
The videos are really great. If anything, I like to see even more tips from your experiences Johnny. Whenever you give insight, that is the most valuable and interesting parts. Keep up the great work!
Well Roth some people cast Gateway into CC so you now how it is:clown:
And I might do something like that though it would be hard to organize it into anything of real form. I kind of use twitter for that
Well, I love for you to really knock it out of the park with our vampire lore. Lots of juicy tips, combos and tricks, if that cool. Any rate, love your work, looking forward to seeing what's next.
How is a crumble result guaranteed in this case? Doesn't that depend on how many wounds they recieve?
I think it is because if they have 3 ranks, a flag and charged that gives em +5 in combat resolution... so it almost guarantees a crumble.
