Gladius Rex
Wight King
I didnt say you said 10 anywhere, i was just pointing out that you are probably not going to win by huge margins against most other units and if you are winning by that much, you are fighting the wrong things with your elite graveguard, that is what i was implying, it was not a quote or I would have posted your quote at the beginning, sorry for any confusion there.
I play alot of WoC and HE.
HE Spearmen do not come in blocks of 40... that would be silly, they come in blocks of 50, because all 50 get to attack if they horde out with spears, so why not right?
I agree that 25 is a small unit in 8th ed, thus I tend to run 30 (as stated).
Now you can attempt to win combat in the 2nd or 3rd round of that combat, but why hold your elite unit up in a combat for half the game if you can hit your opponent, break steadfast, win combat, break their unit and overrun them in one swoop?
I agree with you that Graveguard are elite troops, noone is arguing that (though I would argue our core is probably not even average).
Some of the size of units depends on the points you play as well. If you are playing in smaller point lists, 25 may be a big unit if your opponent is playing elite armies with expensive models.
We tend to run games between 2K and 3K here, and most units I see are about 30-40 models. Most of them Horded out (because its like the new toy syndrome), so that gives them 3-4 ranks. Most of the time, with the exception of the HE spearmen I just mentioned, i see 3 ranks, so going in 6x5 not only gives me a good chance to still win combat, but i know if i win that combat, i will be removing steadfast in round 1 of combat (regardless what turn that is) and causing them to roll their LD.
If I attempt to tie them, then its a matter of pure combat res and wounds delt. So again, unless you are killing 2pt slaves or goblins, you are probably going to have a pretty close combat res and if you end up on the wrong side, then your crumble and you have to IoN to keep up, because once you start losing combat, its a downhill slide now that you can't regen save the crumble.
So for me, I break stedfast as soon as i possibly can. If they don't break, then typically i have a swift moving flank charge coming their way (also easier to move around a unit that isnt quite so wide!!!)
Now having said that, i think the "average" units are a different story. My skeletons I do tend to go horde if I put spears on them (rare, but it does happen now and then) and I have horded out ghouls before. My Zombies (in rare times they get fielded) are often horded out because i consider them an obstacle and the bigger the obstacle the better IMHO.
It is honestly is hard to go wrong with graveguard. HW&S or GW both work fine! Horded out or 6x5 or 5x6 even, still get the job done. What you want to do may just depend on your enemy, just take a musician to you can change your mind as the game progresses and all is well.
