Grey Knights...
From experience I have had 90 orcs charge some Paladins and GM and get all the PF attacks into the unit, thing to keep in mind is you don't do your pile in moves until after all assault moves are made, as along as you can get all your PF's into B2B you should be fine, this does come down to how you position your orks before the charge as well. 5 Paladins will not slowly grind down 90 orks if they have 3 nobz with PF to deal with, this is basically why Paladins are not a killer a unit, they are expensive and they die just like normal terminators when it comes to S8 Ap2/power weapon attacks, in combat they just provide twice the combat res). 5 Paladins are still only dishing out 8-12 power weapon attacks and 2-3 thunder hammer attacks (depending on charging, etc).
Not sure how you think the GK player can stop a nob attacking, if I was a ork player that would be the first model I get into b2b and i would be putting on in B2B with the character, its not like you can target him so no reason for him not to be right at the front of the unit so, if we are talking about the paladins charging he has a 6" pile in move and he only has to be within 2" of a friendly model to attack.
Grey knights are the most effective thing against grey knights without a doubt.
Purifiers are stupid and wrong and should never be troops.
By my own admission I rolled exactly what I needed, if you roll exactly what you want then they are good, if someone charges you with mutiple units then they are just increasing the chance a GK will get a good grenade roll on something, against the Orks half the results are of little use (ld, I1, no effect), its really just 2 and 6 that are the killers (and 6 is only useful against certain armies). I think mindshackle scarabs are wrong (especially at 25pts), all the new books have silly things.
To be fair, Grey Knights are supposed to be a super rare elite of the elite of the elite strike force that can take on anything, so it would be expected that they would hardly ever lose- its just that too many people are bringing them to the battlefield.
Every single army is described as the badass deadly threat of deadliness. Like the Tyranid should just eat up everything and be able to bring x5+ times the points of the opponent since that is how they roll. Hell, my Dark Lances on my Ravagers should be S20 Ap1 and auto-hit if you're going to use fluff as an accurate description.
GK is a mess. You can try and sugar-coat it but as with any top tier army, I'm not buying it. For instance, the psy grenades, it is not enough that I move in for a multicharge on an already tough unit but the combat(before it even begins) can be decided with a D6. I can tell you from the opponents perspective, getting killed by these are anything but 'amusing' to watch. It feels like losing the combat before it began.
Necrons aren't exactly the scariest opponents in close combat though and often enough they need all the help they can get. I2 is a problem, if you lose, you're going to get run over and you will most likely strike last. The only source for these are HQ choices and lords, the latter being quite expencive if you give them even the most basic of gear. A scythe and mindshackle scarabs would land at 60 points. In essence, be suprised if you see more than a few of these unless you're facing someone crazy enough to bring a full court of lords.
In short, necrons are for the most part a shooty army with mid-ranged weapons that can't, bar for a few very expencive units, do much in combat(and none of these can take scarabs). Therefore, the scarabs are more of a nessecary boost that *might* save you... Maybe... And they come in a very limited supply and only affects a single model.
It's not that easy but it can be done, and I've seen it happen before. As you said, how you position the Orks before the charge matter. Now 90 Orks is obviously a lot of models so they will eat up a lot of surface area on the table. If the Ork player is going second then he knows where he should place his Nobz, but if he goes first he doesn't know exactly how and where the Grey Knight player will set up, thus in all likelihood he will split up his Nobz. All the Grey Knight player has to do is to set up his Paladins in a refused flank and chances are 2 of your 3 Nobz will be out of the action for several turns.
That outcome is easier to achieve when you throw a Land Raider or Stormraven into the mix. The speed the transports add to the unit allow them to 'avoid' the Nobz for a short while, which would delay their involvement in CC for a round or 2. This effect can be increased by creative use of Tank Shock, since the Nobz would have to go around the vehicle to get to the Paladins. However using Tank Shock then comes with the risk of the vehicle getting busted by a Nob doing Death or Glory(more so with the Stormraven). This might be easier if I posted Battle Chronicler screencaps as diagrams to illustrate what I'm getting at.
It is true that Paladins aren't very effective at fighting hordes, however when a unit reaches a certain mass, its size begins to work against rather than for it. Anyway, aren't a normal unit of Boyz only allowed to have 1 Nob? If you're talking about 3 seperate units of Boyz then that changes everything, since 3 not so large units are much more flexible than 1 extremely large unit. If I wanted to use Boyz to stomp Paladins I'd much rather use 30 to 40 of them.
Perhaps so, but if a codex writer buys into the army's own hyperbole like you say and really writes their rules in that manner, the game wouldn't be fun for either casual or competitive players as said army would simply curbstomp everything else. The 'Space Marines are da bestest' mentality that often appears in GW fluff is too close to Mary Sue-ism for my liking.
As Dancey said, Mindshackle Scarabs pale in comparison to Psychotroke Grenades. The Scarabs can only ever affect 1 model at most, whereas the Grenades affect everyone you're in combat with. There is no doubt at all that Grey Knights are one of the 'top cheese' armies of 5ed.
Oh I was thinking of 3 units, not one, I didn't know you could have a single unit of 90 orks! never seen it done, most I have seen in a single unit so assumed they had a max size :p I don't mean to say I think orks are some magic counter to Grey knights, its not just the Noz, death dreads, killa kanz, warbosses, nobz mobz, the 3 killa kanz mobz list with KFF abuse isn't exactly uncommon.
Paladin just are not that good, they are far to hit and miss because of the points cost and low model count, they are scary if you don't know how to deal with them, thats about it. Really I think lists that rely on them just add to the rock/paper/scissors aspect of the game.
As for the rest, I use Redeemers, stormravens and Paladins in my lists, so I know how they effect it, the Redeemer is actually one my favorite things to use since playing a Ork KFF list and people who hide longfangs in buildings, I won a local tournament thanks to using a stormraven and plenty of strikes, 24" move and PoM on a multi-melta is insanely good :)
Not really, Psychotroke grenades are great if you get the right result but half the results will have little to no effect on the combats. So the results against Orks:
1: Nothing
2: Really good against everyone
3: good against everyone
4: Ld 2, thats great unless you against someone who is fearless, like a massive unit of orks?
5: Reducing someone to I1 isn't exactly that useful if you have I6/7
6: Well its great if you against Orks, pretty terrible aganst anything with I4 or above, like with marines you have couple of guys hit themselves which in reality you take off as casualties anyways. Its useful if a powerfist guy hits the unit, thats about it (still talking about marines).
So really you have 2 good results and the rest are very situational, its Rad grenades that are plain broken (as they effect instant death), not Psychotroke grenades, Psychotroke are not reliable enough to be broken. I think the problem is people only remember the times someone has rolled a 2, they forget all the times someone rolled a result that had no effect on the combat (which is what very often happens). Its abit like when you have shitty service in a shop, people never remember the 100's of times they meet lovely, friendly staff who went the extra mile for them, they will however remember the one time they had bad service for whatever reason.
So thats 4/6 good results against necrons, same against my DE or 3/6 depending on the units. The unit itself that carries it is no pushover either, unlike the rather lame CC capabilities from necrons or the devestation wrought on DE units. People remember these things because it isn't a tiny aspect of the game that changes.
On the other hand we have an item that won't be common in a list, in many cases you won't see more than 2 of them. Even if they are with a CC unit with a lord attached or overlord that unit is going to cost a massive amount of points.
And it its not like GK will make getting there easy either as they have a solid shooting phase as well.
Danceman, reducing the leadership to 2 isn't going to make a massive difference, I know when I have charged a unit with strength 5/6 power weapons into a necron unit they are usually testing on double 1's if I was trying to destroy the unit, you also have the flip side of this, I may not want to break the unit, I might just want to beat it by 1 or 2 so I'm locked in combat for his turn and don't get blown to bits (say if they have a doomsday ark).
Who uses the Necron CC units other than Wraiths anyways (with that 3+ invul save, 2W and rending), Doomsday arcs are very handy against GK, especially with AV 13 to the front and sides and the S9 ap2 pie which can ignore crew shaken and stunned if I remember correctly. What item are you on about? the stupid prisim thing that makes you roll under your wound or die? I've seen Draigo taken down by take a few times (not my list, I don't normally use special characters), usually because he has taken a few wounds before combat. Its hardly as it Necrons struggle to deal with transports with all those gauss weapons which will always glance on a 6, I think the only vehicle I have which annoys the hell out of necron players is my venerable dreadnought. You know what I really hate, bloody scarabs! they always go after my Redeemer, every now and then they sneak in and bam, I'm armour 11 (so I'm a giant Rhino :( ).
I wasn't aware DE shooting phase that was lacking? its certainly not when you can have 3 ravagers and 6 raiders all with dark lances which will outrange everything but the riflemen and stormraven, grey knights have a solid shooting phase if they
1) get out of the transports (and get blown to bits by mass dark lances)
2) are with 24" range
DE are by no means hard done by, they are actually one of the list that are very good at beating GK, especially with every vehicle able to make enemy range attacks -6" and having a 5+ invul save.
It does enough, there really should be a whole lot more "nothing" results for the tiny amount of points spent. Better yet, no auto-win results at all.
But that is GK is a nutshell, lots of cheap and useful upgrades to deal with any situation. Extremely easy to create very strong synergies. The fact that you cannot truly hang back and shoot like other armies isn't an issue really(least there is something you can't do better than everyone else). Why? Because you're rewarded for getting within your 24" zone and your weaponry is both effecient and accurate, plus, what is left is going to contend in close combat with units which makes many elite choices for other armies look like cannon fodder.
DE and Necrons might not be badly off, the former especially but GK doesn't even know what being badly off means. You have to deliberately make poor army list decisions in order to make a "balanced" GK list, and that's saying something right there. Was same kind of rhetoric going on during 7th edition with the VC book. Several members tried to defend their army, trying to explain that the book is great in terms of internal balance(which means nothing in the context of the game).
This is not to say the army is unbeatable but doesn't really mean much either. Daemons weren't unbeatable in fantasy before either but bloody hell did they have an answer for everything. Guess what? Same author. I was pleasantly suprised to see Necrons in the state they were in as the army actually have strengths and weaknesses, and can't just fix them with a piece of equipment or psychic power.
You mean like haywire weapons? 1 nothing, 2-5 glanced, 6 pen, regardless of armour value? have you every tried the tremor stave army with a C'tan with writhing worldscape and Orikan, can't really move your tanks on the first turn an then you can pin them down forcing me to footslog while dropping doomsday arks on my head, its not a pleasant experience, it can be countered but its a complete nightmare in DoW unless your like me and tend to use outflankers, of course it does mean I have to reserve everything and lose the use of Psychic communion.
Had you noticed that Guard are still the top list, thing with grey knights is against so many armies they have to stay in the transports as long as possible, plasma and melta spam will make a mess of them. Guard have no problem opening the rhinos and them dropping S8 AP3 pies on units.
Thing is Grey knights are new so people continue to moan, I don't for a 2nd think that grey knights average, they are a powerful army without doubt, it has some broken things in it. Psychotroke isn't reliable enough to be one of them, the problems are:
Draigo
Purifiers
Crow
Hencemen spam
Rade Grenades
Psybolts
Paladins are good but are just so hit and miss,if I play a marine player without to many AP2 S8+ weapons they will be godly, of course they have one of the best counters to them (alone with DW), TH+SH termies which are alot cheaper. DE will destroy a Draigo list with all those dark lances and extra range.
Purifiers are poorly designed, the upgrades are too cheap and they shouldn't have so many psycannons, just invalidates the other power armour choices when Crow is used. I am very much against SC that allow you take multiple units that are elite as troops, those kind of lists should be back of book permission only for friendly games. They would be so much more balanced if they remained elite but just counted as scoring.
Rads are just silly, stupid and wrong, enough said.
With Psybolts the idea is good but the actual rules make no sense from a fluff prospective and should not be usable on autocannons! I like the fact you can use them on assault cannons and make psycannons for vehicles, means I can use FW models I like. Personally I think they should just ignore invul saves or something.
The daft thing with GK's is the power builds will usually lose to the balanced builds, with grey knights is usually comes down to who charges wins. I will happily charge a unit of strikes into a unit of Paladins and win combat, why? because I only need to cause 3 wounds, activate forces weapons and cause 6 wounds, even if I kill 2 with sword and 1 with the hammer I should win the combat be a decent amount, I just my paladins and GM on his Draigo and paladins, GM for grenades and hammerhand, paladins for force weapons, its usually very messy an more often than not you can kill Draigo be either breaking the unit and one guy being a live and chasing them off the board or through armour saves caused by fearless. I think this is a very different situation to VC and DoC of 7th ed.
DE do not know what badly off is either, they are one of the best armies for beating grey knights! (same as guard and Tau). Ba can even do it depending on the list, but thats nothing new with 40k, space wolves are still one of the top armies.
I played a DE player not so long ago, he ended up bitching about grey knights, he seemed to think his list was fine, yet everyone down the club had told me all those horror stories, it was actually a close game, more so because he ignore the redeemer early on, he gave up on turn 5 because he had no anti-tank left and my redeemer just exterminated his wyches (who thankfully didn't have haywire). Basically my list was better than his so it was broken? this totally ignored the fact he managed to kill everything but a venerable and Redeemer. It came down all my strength 6 template weapons raping his infantry (no FNP for you!), I hate KFF's that much! I refuse to use purifiers on principle. This is something I always mention when people moan about my GK which quickly results in a "well fair enough, for grey knights is very balanced" or "well the problem with grey knights is when someone knows how to use them" and "strength 5 power weapons are broken against marines" (why he doesn't take a lib is beyond me).
The main thing I hate is the complaining about force weapons on everything. All it does for strike squads is get you an extra kill or two, and for terminators, well vanilla marine terminators get 3++ saves and will still ID anything T 4 and below, and probably have enough attacks to do it to anything bigger. The only real problem is rad grenades, because Draigo is nowhere near as good as he is made out to be, Psybolts are painful but nothing broken, Crowe is a free kill point and purifiers still suffer from being power armored bodies. Henchmen suffer from being not marines when they're popped out. Even rad grenades are fine, just don't charge your entire army into it at one time so they all get no retreated/run down, and shoot them. People just can't get past how things look on paper.
logan054: Fortitude > haywire. High initiative, rad and psy 'nades is a real pain in the arse. Darklight-spam and wyches are pretty much what you want vs GK.
Personally though, I no longer play the stock MSU lists and have noticed this is actually a better approach. Indeed, at games at 1.5k and below I am extremely unerwhelmed by blasterborn venom squads which are supposedly a "must have." Many of the broken combos being presented are due to people playing at 'Ard boyz. I would argue that playing 40k at high points increase the level of "brokenness" the higher you as it makes unit min-max spam more viable. It often comes down to who brings the biggest hammer.
However, like Zanos just did, just dismissing other players experience as nothing more than theoryhammer is not very constructive or useful.
The main problems I've found are the psychic powers, high initiative attacks, fortitude, rad and psy 'nades. None of which are particularly trivial problems. More or less moved away from haywire weapons because I know it will hurt me. GK also have a fair few tricks to challenge our ability to use terrain at our advantage which sort of messes with the whole say away from shooting. Not to mention a good GK player shouldn't have that much trouble targetting my paper-armoured transports either. Put simply, if you aren't prepared for GK you could easily end up with a horrible match up. Unfortanately, doing so may very well screw your chances versus other armies. It may sound as if I say "Woe is me" right now but when playing DE I have a much better chance many other armies(daemons, lol).
So yeah, I'd say haywire weapons and mindshackle/terra labs sound pretty tame compared to rads/psy 'nades. The latter two is likely to have a much greater impact. That said, I do welcome the challenge but I completely disagree with DE having it easy vs GK. The GK player have to ignore lots of the great options available to them in order for this to be true.
Fortitude is certainly a very good power, then again so is a deathcompany dreadnought have the same ability constantly activated (basically) and then having a pair of bloodtalons, thats insane, whats worse its a troop choice only limited by the number of DC you have, forititde however does not beat hayway unless its against a dreadnought, if its against say a landraider then it is easy enough to glance the thing to death! Haywire is silly on wyches.
Well I won't argue playing 40k at higher points brings out the more broken combos, it does without a doubt, me I've lost to the darklight spam, I've beaten it, I've played DE 3 times now, twice at one 1K (lost the first one as I had never played them, won the 2nd) and also played them at 1500pta and won, that came down to the other guy being a poor player. The 1k list was:
Raider - DL
10 wyches
haywire
Raider - DL
5 Incubi
Lord of much killyness
Raider - DL
10 Warriors
some lace weapon
2 ravager
Was horribly, first time without the raven I got crushed, 2nd time with a Raven I trashed the army, its a really good list untill you pick off the ravagers, once they go down its mop up time, first time I was tabled, 2nd time I lost a rhino and strike squad, he didn't use his range to his advantage, if he had it might have been a different story, he was silly and rushed towards a single unit of strikes with both combat squads which allowed me to fly away and take out the ravagers.
1500pts game was
3x Raider - DL - -6" range
Wyches
Raider - SC -6" range
Wyches (had some character)
Ravager -6" range
10 scourges
some little transport with incubi
some stupid bomber that pretty much wiped out a unit in a turn, if he hadn't been so silly and left the haywire at home he would have tabled my list, then again he might have lost a unit so who knows, then again I only needed one model alive to win because he had so many KP's available.
Which psychic powers have you found a problem? hammerhand? fortitude? Cleasning flare (yes its broken, we all know) Marines, eldar and nids are actually very good at stopping these, high I attacks? only purifiers and termies will have them, if its purifier spam then it shouldn't be hard to pop the AV11 tanks (all 6) and then use your speed and range to your advantage, you have to change you playstyle for different armies. I use alot of strikes, I love using them in assaults against marines. I'm not going to assault a wych squad with them or a Ork mob unless I have already done alot of damage to them (well the orks anyways).
Well I am not dismissing your experience, I think your blowing Psychotroke heavily out of proportion, its basically a 50/50 chance of doing something useful, even less in some cases (like making someone Ld2 when you want to be locked in combat or your going to destroy the unit anyway), 2 and 3 are the real killers, the rest are all situational, that does not make for a extremely overpowered weapon, hell I remember the original advise online, don't take them, rads are far more broken (which they are).
I good player should have no trouble taking out 3 av12 dreads and then staying out of range of army that has a max of 24", if we are talking DE then its actually 18", yet I see you have avoid comments on guard, why? because they are still king of the hill. Someone I play with at my local LGC said exactly the same thing about needing to tailor your list to beat GK, hes a marine player, I had to spend several hours on FB explaining to him why I was beating him, lack of range threats (vulcan list), to many points in characters (he had vulcan and the crimson fist guy at 1k!), general play style, not using combat tactics or combat squads. just saying sometimes you need to look at how your playing your list rather than resorting to tailoring your list, lists need to be adapted when new books come out, you don't need a new list just for one army.
Are you not just dismissing my experience now? I don't agree with you on the psy nades, rad yes I agree, they are stupid, I don't think they should even be in the book, I could see result 2 being toned down from auto hit to enemy reduced to 1 attack (that makes a massive difference), apart for that they are fine.
I avoid commenting on imperial guard because I do not play this army. I would just be playing theoryhammer. I do play DE, necrons and to a minor extent daemons(poor poor daemons).
I wouldn't say so. When I've played GK having brought HW weapons they've been largely a waste of points. I don't mind changing up my list. I just hate having to conform to the bloody boring darklight spam, especially since because of a single army. I hated facing the hit and run armies of WE in fantasy and I can only assume it is equally frustratingly boring to face a DE army like in 40k.
There are options, of course, especially at 1.5k and lower which I more frequently play these days. At these points, the GK player cannot afford all the toys to make the worst of the worst-synergies work. Stuff like reserving with aethersails, make a hybrid list of normally sized units/MSU seems preferble contrary to going all out spam. Much of the spamming tactics peddled on the internet is actually more of a 'Ard Boyz-symptom than anything else. Indeed, I do not recommend blasterborn as smaller games because you do not have enough targets for them to be "low priority." Units tend to matter more individually on "sane" points levels.
Just so we're clear I am not saying that GK will steamroll DE, not at all, but I don't think DE are the nemesis of GK either. Both armies are well equiped to deal with the current meta game. There are some horrible match-ups for DE and, judging from what you say, for GK too. My experience with GK is not like army you play and more in line of the dirtiest tourny-lists you can think of.
http://www.dakkadakka.com/dakkaforum/posts/list/430345.page
Crowe
5 Purifiers - 2 Halberds, 1 Hammer, 2 Psycannons, Razorback with Psybolt Ammo
5 Grey Knights - Hammer, Psycannon, Razorback with Psybolt Ammo
10 Grey Knight Interceptors - 2 Psycannons
Dreadnought - 2 TL Autocannons, Psybolt Ammo
I assume you mean something like this, the height of imagination when it comes to list writing, I've seen the Draigo wing at its best as well, its dull and boring to play against, I haven't played against the purifier spam yet, really can't stand them dreads, certainly effective but once them and the HB are gone any list with decent range will be able to deal with it, more horde armies that might as well packup.
Talking about these lists, for gods sake, why is it whenever you post a list online people only know how to build this type of list or a draigo wing, does my nut in! If you want to use something else its like you have some terrible kind of disease...
The way I say it ranking wise you have:
Top: Guard, space wolves, DE, BA and GK (in no real order)
Mid: Marines, orks, eldar, necrons, templar, DA (cos of DW)
Sisters, Nids, Tau (I don't think they are a good army but the hammerheads make them good against GK)
Yeah, that's exactly the stuff I got fed up with and stopped playing high point games. Same reason why I've stopped posting army lists altogether on most sites and you already know what you're gonna hear. Someone peddling stuff they've read on YTTH or kirby's, or some other 40k-blog. Might be the same issue I've had with fantasy. The games just get larger and larger to the point where the armies that can cover their weaknesses the most can do so extremely well as the points go up.
I didn't much like it when 2250 became the fantasy standard back in the days either. Army lists got so well-rounded and, imo, boring.
But yeah, these days I mostly play 1k and I am more into the modelling/painting part of the hobby than I used to be. Doesn't hurt that is nicer on the wallet since I am pretty good at randomly picking up new armies and then something else. Have tons of half/finished half/started stuff laying around.
Here's to more interesting and less brain-numbingly boring lists. *cheers*
HQ
Grey Knight Grand Master
- Master Crafted Nemesis Force sword
- Pyschotroke Grenades
Total 195pts
Elite
Venerable Dreadnought
- Assault Cannon
- Psybolt ammunition
- Heavy Flamer
- Psyflame ammunition
Total 205pts
(5) Paladins
- 2 Incinerators
- 3 Nemesis Force Halberds
- 1 Nemesis Daemon Hammer
- Brotherhood Banner
Total 310pts
Troops
(10 ) Grey Knight Strike Squad
- 2 psycannons
- Rhino
Total 270pts
- 2 psycannons
- Rhino
Total 270pts
Heavy Support
Land Raider Redeemer
Total 250pts
Well this is what I usually use, I actually try and stick to 1500pts, alot of people seem to want to play 1750pts, a local tournament next weekend is 1750pts so I have been working on building the list up for that points level (just to play some different people), I'm actually going to start using Draigo so people don't want to play the bigger point games! I have spent alot of time trying to make the list fun, balanced and competitive, other people just can't be arsed, it about winning! I remember I went to a club and lost to a ork killa can list (was a different list) and I had one guy ask me why I didn't use purifiers, i said because I want to enjoy my games and he gave me a funny look, like I had some strange growth on my face!
I really hate the lists like the one I posted in the previous post, they just remove skill from the equation, its all about the dice rolls really. Whenever I see a purifier spam list posted online I just roll my eyes, a few times I have actually posted a snide comment like "oh look, how original you have been", like I care, its about useful as the comments I get "well first off a single redeemer is rubbish, oh and rip the arms of your FW dread, make it normal one with w twin-linked auto-cannons and then get another two. Sure don't mind if I do, maybe I'll just throw it in the bin and get some nasty AOBR dreads and stick some cheap autocannons on them! wont that look awesome, maybe I will paint the chainmail and the just devlun mud them like the other powergamers using the spam lists.
With warhammer I'm actually enjoy 2k games (when I play), need to get my VC finished, I did start them up again, need some mantic zombied and more knights of the whitewolf on foot for my grave guard, made one, looking pretty epic considering it's using mantic bits.
2k in fantasy is my 1.5k in 40k. Enough to get a good number of units in and just enough for the units/characters chosen to matter.
I don't dismiss anyone's experience. But if anyone here has a right to complain, it's me. I played against a 6 strike squad 6 dreadnought list. With Daemons. And tied. But I don't complain, because it's all about learning to fight them.
Yeah thats generally what I play now, we do alot of 1k 40k as well, my local GW has tournaments every few months which are usually 1k, it does make list construction alot harder. This one guy wont play less than 1750pts because someone else wrote him the list.
I nearly lost a daemon player once, I didn't know alot of the rules and my paladins failed every single save, game didn't finish because the place was closing, still my DS paladins did manage to bring it back by blowing up a soulgrinder which then killed everything near it (that was funny).
...And I won against daemons back in 7th WHFB, clearly this means everyone just needed to L2P. L2P-arguments is a great way to discover top tier armies. They're typically, when pushed, reduced to arguements that you 'can' win against them. Great, no one is saying otherwise.
It's great to see Daemons *almost* being able to do something and how that experience is a memorable one...
I don't complain during games either. I am however tired of gamers who cannot cope with the fact they've got dealt a strong hand with a new dex/book. Gamers who tries to shift the blame, so to speak, over to player who obviously use outdated book/codics. Of course, it is all about learning your army. That's a given. However, when someone is on the same level of expertise as you and he or she has superior tools you're going to struggle regardless. On the other hand, 40k or whfb has never been a game of balanced armies but even so, this doesn't mean people should just shut up and take it when some armies seem to play in a league of their own.
I've also won games against all odds but a random fluke doesn't prove anything.
My point earlier was that the Grey Knights power levels are fluff accurate, and not the "every army is awesome when described in its own book" fluff, but the actual un-army biased fluff. The true fluff innaccuracy is that there is more than 5 grey knight armies in the entire world.
On a tabletop balance perspective, yes, Grey Knights are broken.
edit: its like the gaunts ghosts books. In the gaunts ghosts books, because the books are about guardsmen, guardsmen are somehow better than chaos marines. Thats what most codexes fluffs are guilty of. The Grey Knights are an exception to this: their power is unbiased as they actually are supposed to be that powerful in the fluff, because they are the elite of the elite. The balancing factor of this in the fluff is the fact there is only 1 Chapter of Grey Knights, and a small chapter at that.
That wasn't what I was saying, I think I have made it very clear what I feel the issues are with the codex, it has some broken combos which frankly revolve around special characters. Purifiers are a issue without doubt but I think it would be far less of a issue if Crow didn't make them troops, I friend of mine keeps trying to get me to use them in my list, its starting to get annoying.
Well this daemon player has beaten all the other GK players in my store so he is certainly a very good player, had a very close game with him yesterday, wouldn't have been as close admittedly if I hadn't made some silly mistakes, main one being getting a strike squad out of a rhino before he DS and using Corteazs ability rather than warp quake (cost me the unit). Thing is daemons actually have one of the best things against GK, characters with 2+ invul save against force weapons. Unless you have either a dreadknight or Corteaz and he gets close enough to assault you will struggle to hurt him (alot of people won't have dreadknights).
Corteaz is however amazing against daemons even without using henchmen, its also surprising how good my dread was once it took apart his soulgrinder.
Point I have been making is that the GK codex isn't the only codex that deals players a strong hand, DE certainly, SW without doubt, guard without question. DE lance spam is going to seriously mess up a Draigo win as usually its a foot slogging army, it could do well against purifers if it can take out a large portion of the razorbacks on turn one, I mean you can have 15 dark lances on your skimmers with a 5+ invul save, I think that save helps makeup for the lower armour value.
I'm really starting to hate monoliths, damn things won't die and seem good at sucking up my army :( (stupid things!) Also you have to accept with 40k you will get bad matchups, The Grey knight codex provides a wider variety of lists but i don't see how that would really matter if they split them across 3 codexs either. This doesn't change that spacewolves are a horrible army for most to play against, before GK came out it was all about spacewolf Razorspam, when the codex comes, maybe Chaos it will be all about the next thing, maybe TS spam? Really depends who writes the book.
Some of the codex's that are suffering are a edition out of date, soon to be 2, alot if people seem to think GK, necrons possibly DE are all designed with 6th ed in mind, perhaps this is also some of the problem. Think of Skaven, still hate playing against them but I think the dreaded 13th certainly shows is was designed with the change to magic in mind, not a balance spell but then against neither is Low of shadows, death or life.
Tau can still hold out against Grey knights because they are still a good gunline, railguns make a mess out of GK armies, I've seen paladins ripped apart by them (The sad thing with Paladins is they rely on Draigo and his ET and SS to get across the table). DA deathwing are very good against GK because they ignore all the advantages GK have, power weapons vs SS, TH vs T8 models, its not pretty, I know from experience unless you have psyk grenades in units they are going to need to be very lucky in order to survive a attack.
You're not the one making the L2P-argument.
Not saying GK are unique in their ability to make filthy lists but they more lists that are considered broken. DE have a single build really, many competitive builds but they all have rather glaring weaknesses as well. This beacause many rely on stun/locking which is increasingly becoming a very bad idea(fortitude, living metal). It is no wonder that in nearly all tournaments you see so many use darklight/venom spam lists. I blame GW for this obviously, as too often they introduce a rule in one codex only to strip its usefulness of it in the next. The only reason to field Scourges would be their splinter cannons but then again, I rather take venoms for that.
I, like yourself, is quite simply tired of the copy/paste lists so I'm exploring WWP and other variant lists relying less upon the MSU-spam of "the most powerful unit." It is however unfortunately so that most people will have a particular view of, lets say, GK as people are oversaturated by the usual suspects of filthy lists.
Like the psy 'nades. They don't look all that dangerous on the face of it perhaps but rather because of the units that have them. Knocking over them units are not easy task to begin with and even the slightest disadvantage thus become multiplied many times over. Not to mention when they do work really well it is game over for the unit in hand. This unit probably are quite strong in comabt as well which further magnifies the impact of them. You may think they're situational but I dread them. At the roll of a dice and my plan might just turn from a great plan to a complete disaster. The game is decided on dice, yes, but this is something I cannot possibly control. This is a big reason why they're so reviled I think. They reduce a perfectly planned assault to a roll of the dice.
The point of them being situational is lost because of the reason it takes the combat result, potentially, completely out of the hands of the opponent. Any item that can alter the result of a certain phase so completely will be hated.
I think several armies actually have multiple builds, Guard are the first one that springs to mind (they can be horrid to play against), Numbers is the main weakness of most Grey knight list's, I actually don't see the problem with rules like living metal, I think its rather good thing, it stops armies like DE totally dominating other armies, they are still one of the best anti-tank armies about.
Sadly nothing we can do about it, sadly people very often like to safe the other options, other honestly enjoy powergaming, A guy in my store like terminators so he uses either Draigo wing or a TH+SH heavy list, today he played me with a list with 20 TH+SH termies, great fun for annihilate :O:'( Actually won, was amusing I tank shocked a unit of 10 who had assaulted my Redeemer, they failed the leadership test :slapface: so I chased them off the board with a stormraven!:innocent: I keep telling him the reason why his dice rolls are failing is because he is using a silly, next game he uses a list with 25 Terminators in :slapface: He only draw because he had no scoring units and couldn't kill the other guys last rhino :happy:
I told him about the purifier spam list and he seem very excited :rolleyes:
While you are right people are certainly oversaturated by GK filth builds it gets to point that people will just say "your winning because you have grey knights".
I certainly appreciate how good the nads are, I personally find Draigo makes a bigger difference to the list than psy nads, fact is a T5 eternal warrior with W4 and a SH really does absorb a crap load of AP2 instant wounds allowing the Paladins to get across the table even if they lose the transport.
Id like to point something out- someone who takes guard so he can spam melta vets in chimeras is not a guard player, hes just a powergamer who picked up a guard codex.
A real guard player does it for the love of tanks, and infantry platoons, and all things military. A real guard player runs leman russ squadrons and infantry platoons, and when he sees rough riders, he thinks "guys on horses with dynamite lances? Why not!".
