HERO's Undead Legion Workshop [competitive]
I find the Staff of Damnation as more of a utility item. It's great for protecting the flanks if you get charged by something that intends to stick (like demigryphs or other things that take more than a couple of attacks to break) since you can't gain supporting attacks there.
I tend to structure the magic phase:
1) Check characters in range of Death caster. If so, attempt character snipe. Generate power dice to sure up the phase. Great way to deal with Dawnstone characters before they get into combat. Enemy will have to throw dispel dice against these to prevent damage.
2) Support spells. Raise as many as possible, if dice are left, HV or VHDM.
3) Bound spells. Last few dice to throw either RoFD, SoD, Light of Death or other bound spell at the enemy once all the dispel dice are gone.
Rinse repeat with Casket of souls generating +d3 per turn.
I'm happier with a seperate wizard/general over putting all the eggs in one basket with a tooled-up vampire or character, costs about the same, but it's more wounds and they're targeted seperately (and the odd miscast won't kill both in one).
Vlad may be a good suggestion. Will try that out and see what happens.
Against MC/MI, I don't see GG as a liability. You're always hitting them with S6, which is the crucial point where their armour will fail (unless they're skullcrushers in which case that's a completely different kettle of fish).
I find walking skeleton archers behind the army to be fairly effective as a caster bunker using the fast elements of the army to ward off potential flankers and using the larger skeleton warriors only for the most important caster so there's no chance of being reduced below 5 models and being unable to make a Look out Sir!
I like your thoughts on the magic phase, I would prioritise movement spells early on a bit more since the army wins or loses with the Grave Guard hitting their marks. I am interested in your thought on the Rod of Flaming Death, I have never used it since I feel its effect is to situational.
As to the point on Monstrous Infantry or Monstrous Cavalry, it's not so much that the Grave Guard can't kill them, it's that they take too much damage in the process. In my experience even Ogre Bulls do significant damage (certainly on the charge with their Impact Hits) to the Grave Guard horde. Sure the Grave Guard will beat the Ogre Bulls but the enemy will do damage faster than you can raise them back. The addition of a Vampire Lord (I even have two, a Light blender and Vlad) can really reduce the number of incoming attacks. It's such a shame Nagash forgot to raise good 'ol Konrad, he would have been a great addition to the GG-star.
As you said Skullcrushers are on a another playing field, but most WoC players I know do field them so I feel you absolutely need a tool for them. Redirecting them is all well and good but there always comes that when the beasts must be faced head on. Maybe your gaming community is different in this regard.
Skeleton archers are indeed the better bunker for casters, maybe you could even use 50 of them to fill the core tax and add Khalida to add a second avenue of attack into the army in the form of massed Poison arrows.
Rod of Flaming Death works great against units that need to move to make their points with average toughness. So...pretty much Elves.
With Undead Legions movement isn't as much of an issue, so Book of Akhan (only way to guarantee VHDM) falls under the Bound Spells step in my experience.
Skullcrushers can eat a Screaming Skull catapult every turn, S9 d6 wounds no saves. No one in their right mind takes the blasted standard on Skullcrushers, because it actually makes them easier to wound.
Reactions: Alastor
