Only if you manage to keep the 1" distance, though. That, more than anything else, makes them seem dedicated monster/elites/warmachine hunters to me.
Being Fast Cav, they may often be out of reach of the general's march bubble, and 8" movement will give you a max of 6" of unit to cross if you're going to keep the 1" distance before and after. That's 3 Monstrous Infantry, 7 regular infantry or 6 Chaos/Orc-sized infantry you could sweep over, tops.
So if you're going to be hunting out there, keep to small, elite units, Monsters, and warmachines. Alternatively, you could keep them behind your own lines inside the march bubble, then try a sally, but that's not really viable either: even with the march, they need to get through one of your units and the enemy unit and the space in between - and you had to forgo charging the (obviously) close enemy with your front ranks. Meh.
Seriously, use them to murder hydras and make chaos knights "crap bricks". Do NOT run these against Skaven. Lots of magic shooting, huge units you can't cross, and the Abomb will likely survive and then WILL charge and eat your ghostly dudesmen with its magic attacks.
