How to kill a Bloodthirster
Tal Rasha, so you had 3 characters in that unit? Wow, it must have been 6 wide to get full command in that case. Either way if the BT survives the first two rounds, he will kill one of the vamps (if you're smart you accept with your thrall round 3) the turn your champ can't take the hits for you.
Ruderat, that's why most people don't take a Kastellan...
Blood Knights whitout a Kastellan may accept a challenge. But iff you got 4 Blood Knights (1 got blown up {flamers, furies, missile's
]) in combat whit a BT you can't revuse...
So indeed as I say already BK r no option for a BT
I played in a tournment this past weekend and I wiped out the deamon army except the Bloodthrirster. He has hatred so he had to overrun and ran it to a unit of Ghouls. I just kept raising the unit champ and he stayed put the last few turns of the game. I really think that is the only way VC can kill him.
The tournment I played in had no comp and I had a Vampire Lord on Zombie Dragon w/Red Fury and I still wanted nothing to do with the Thirster. We rolled it up a couple of times and everytime the Thirster came out on top.
-Von Brimstor
You can always refuse a challenge if you don't have a Kastellan and nothing happens. The 4 Blood Knights fight as normal.
I was flipping through the book to search for a way to possibly kill a Bloodthirster and this was the best I cam eup with:
Vampire Lord w/Balefire Lance, Walachs Bloody Haubark, Cursed Book, Infinite Hatred and Red Fury, and mounted on a Hellsteed
Even though the obsidian armor negates magic weapon rules, you still get +2 from the lance on the charge, and being S5 is still ok when going against a T6 creature.
You get an armour save 0f 3+ which isnt really anything to sneeze at and a modest 5+ward!.
The beauty is the Cursed Book!!!! Hit him with this and that WS10 is GONE!!!!!!!!! For one round you can have possibly enough attacks to wound him as long as that pesky ward save doesnt get in the way. He will crumble as long as you get 4 wounds in. HE shouldnt even be able to touch you.
Also, you have a flying mount which may possibly get lucky and successfully kick its face!!!!
Are you serious? Let's assume you are;
:| First of all, yes, a Bloodthirster will of course sneeze at your 3+ armour save.
Most Bloodthirsters I've seen so far has been:
Obsidian Armour
Firestorm Blade
Immortal Fury
Which means no armour save for you. At best, you get a 6+ armour save.
The Cursed Book doesn't work when you are attacking, it only works when the enemy model is trying to hit you. So there's a good chance that you still will miss with at least one or your attacks hitting on 4's.
Oh yes he should, 7 attacks hitting on 5's with rerolls and wounding on 2's he should on average kill you in the first round in spite of the Cursed Book.
While it may crumble if you can do enough damage, I have yet to fight a Bloodthirster without a BSB nearby, making him stubborn.
Yes, luck. You will need large amounts of it.
Count Von Brimstor, a Bloodthirster doesn't have Hatred, so it isn't forced to overrun.
Well, i've not tried this and it's from the top of my head *but* somthing that might have a chance against the thirster, it's alot of points to field but well... it could kill it. using the standard bloodthirster stated earlier.
First off
You need a Vampire Lord with the powers Red Fury, Beguile and Walking death. Crown of the damned, The Flayed Hauberk, The Book of Arkhan.
He then needs to be supported by a Vampire with power Forbidden law (Beasts) Then Equiped with 2 Power Stones.
Quite simply get the BT in combat with the Vampire Lord, 1 on 1, in a challange as long as they're fighting each other. Then with the Vampire supporting near by cast The Beast Cowers on the BT as it is an unridden monster, yes it has Magic resist 2 base but it's worth a shot for the spell. Then Proceed to cast The Bears Anger on the Lord. Then the Lord uses his Book of Arkhan on himself. In the combat try and Beguile the Thirster.
In the combat the Lord should have 7 attacks at str 7 with tougness 6, 4+ ward and 6+ save after modifiers. Re-rolling hits and wounds if you get Beguile and the book off, striking first, with Red Furry too, on average you can dish it 4 wounds before it can do anything. If you didn't manage to get the Best Cowers and it strikes back it should cause 2 wounds, you should win the combat and be able to kill it off next turn. If you get the Best cowers off on it it is screwed.
I'm pretty sure The Beast Cowers does not work on a Blood Thirster; I checked the Warhammer Errata but the only reference was that they would follow some of the rules for monsters. Doesn't specify which ones. A Bloodthirster is a character as well as a monster, following some of the rules for each. I don't have the main rulebook on me but I'm pretty sure this won't work.
Actually that's probably the best setup I've seen for taking out a bloodthirster; Demon armies headed by a bloodthirster will hopefully be light on the dispel dice. I'd drop Walking Death for Infinite Hatred though, and not depend on the Book of Arkhan. I'd actually have to do the math on whether he has a good chance of surviving or not. Still, one dispel scroll (or whatever the demonic power is called that does the same thing) will ruin your day. And you have to be in combat before you cast it. I wouldn't risk my general like that... unless I knew for sure I could get off Bears Anger.
okay, im new, so don't kill me if this i stupid, but what about a courple of vamps with forbidden lore (light) and 2X power stones to blast the thirster with burning gaze.
2 vamps will be able to generate 12 powerdices. yes for one turn, then its back to 4, but it might give a lot of damages to the thirster and be quite hard to dispel.
the burning gazes is also useful agains the rest of the deamon army.
Bloodthirster is explicitly a monster so will be affected by Beast Cowers. It's a very good option against it, and as usual, magic-heavy is the best option. What a surprise...
I agree with EvC that the rules seem quite clear regarding Beast Cowers and Blood Thirsters.
Obviously basing your plan on any spell that needs to be cast on a Blood Thirster has inherent costs. If it is a pure Khorne list then you'll probably be able to pull it off, if how ever the army has anything else providing dispel dice or scrolls then it will be a tough stunt to pull.
If your opponent is fielding the Banner of Chaos Glory then this is where you should be targetting your better units early on, trying to tarpit or deny the Thirster decent combat in the meanwhile.
Magic resistance (2) but you can purchase an upgrade to (3) (from my new daemon book, know thy enemy!!) so targeting it with spells will be very PD costly, even with a magic heavy vamp army, plus start factoring in miscast risk and that you won't be getting on many IoN if you're using the PD offensively and I don't think it would be that effective.......
