Is a strength test magic damage
Olethros70 said:
@Sigmar's Bane: You are forgotting to add that in the same boxed text is clearly stated that no salvation allowed against instant kills if not otherwise specified. For instance, Killing Blow, an instant killing special attack, just avoid armor saves and regeneration, not ward saves.
Arnizipal´s Black Horror causes an special kind of Instant Kill if a strenght test is failed, and specifies no armor saves allowed. By extention, ward saves are, MR improves Ward Saves when spells involved, the Strenght Test is caused by a spell so nothing was wrong between Skittelz1981 and his opponent.
Regarding the Look out Sir, not sure what you mean. It can be tried (2+ in a D6) against template impacts unless 4 or less miniatures in the unit, and vortex uses a template. Or you tried to mean something different.
I didn't forget to add anything. I didn't mention Killing Blow (which does allow a Ward Save, even if it is only a Parry save) because I didn't think it was relevant to this particular case.
With respect to Look Out Sirs! I was referring to spells like The Dwellers Below, not spells that use templates.
The OP didn't mention what the spell was, just a magical vortex.
Reading the other posts, I get the impression that it was the Dark Elf spell Arnzipal's Black Horror. This spell specifically states that its victims do get a ward save. This is unique to this spell, and doesn't infer that other vortex spells that require tests to be taken are handled in the same manner with regard to ward saves.
Actually, purple sun says "no saves of any kind allowed" so there would never be any confusion about that one, I bet the same is true for other vortexes.
As far as I know, any vortex spell states which saves are allowed, if any, or what are not allowed (and by interpretive extention, which are allowed).
