Mortis engine
Two mortis engines are great and whats better than great...2 mortis engines.
@2250
1 with tome 1 with out. You can do this with Mannfred using the lore of death near the non-tome engine and 1 LV2 Necros and 2 LV2 Combat Vamps
@2000
2 Master Necros. On with Periapt and the other can carry to anything that helps the build.
Again on Necro has LoV and the other LoD. Run the Death Necro near the non tome engine.
Ravenheart is on the money with the "Good Things come in 2's" comment.
2 engines, 2 Lores and 2 Master Necros should do you well.
totally agree on the pair thing. vlad and isabella. kemmler and krell. its all about synergy
[/quote]
That's a very different situation though. A Pair of Terrorgheists/MEs etc. adds redundancy, as well as giving additional benefits: e.g. the stackable benefits from the mortis engine.
However, Vlad and Isabella are dependant on each other to get the most out of them, but have no redundancy whatsoever (in addition to being hideously overpriced). There is synergy there, but it's completely forced, and is (at best) a small compensation for investing too many points in the pair.
If one terrorgheist out of a pair dies, then the other one can do exactly the same. If Vlad dies, then your frontline force is now one model with T4, 2 wounds and heavy armour. Likewise, if Kemmler dies, then Krell can hardly take over casting. Or, if Krell dies, you might as well send a jam sandwich to the frontline.
Anyway, on topic, I'd concur with running 2 MEs - one with the tome. I have to say though, I the idea of casting with my general terrifying. But then, I speak of someone who is more than capable of miscasting on 2 dice. :rolleyes:
I'm not really seeing the Kemmler/Krel thing, here. Krell could be sucked into a challenge with a worthless Champion, leaving Kemmler to fight, and anything requiring Heroic Killing Blow to kill will kill Krell. (W4, T4 SV4+, if passed negate magic ability? Always Strikes Last? I don't see how good that is) Also, Krell doesn't really benefit Kemmler. At least Vlad/Isabella you get a half-useful benefit.
Krell + Corpse Cart = dead monsters, even without HKB. And Barrows. Always Banner of the Barrows!
I've run vlad and his wench before. Put her in a small unit of zombies and let her die. Vlad actually becomes useful then.
I recently switched from a list with two gheists to a list with two engines. I'm 0-3 so far. The problems I've found is that my movement has become more restricted as I try to manage the regen bubble covering everything I want it to cover. I play more defensively with less aggression. My opponent is able to get the charges he wants. As soon as one engine gets popped the overall net effect of the list is reduced. It's countered easily by fire, so if you forget something has a breath weapon (Warsphinx upgrade) like I did it will ruin your day.
A two engine list for sure has a steeper learning curve than the two gheist list. I would recommend taking more chaff than normal. I normally take 3 units and try to get Raise Dead. I've changed my list to have 6 units of chaff. If I'm not getting my charges then I'm not doing enough to stop him getting his.
