Must-Haves vs. Orges?
With the vast majority of Ogre units causing fear themselves not sure how much use the Screaming banner is going to be with the Skeletons. Unless you stick a terror causing model in with them.
Yeah, but then you don't get the banner of swiftness. It's kinda 6 in 1 and half dozen in the other. I mean you could make either one work, but the banner of swiftness will work all of the time, and I would bet that the ogre player will have a BSB, meaning that he'll reroll failed anyways.
In Portugal's current meta, regarding Ogre Kingdom lists ( 2x 4 mournfangs, 9+ ironguts 2 ironblasters and always hellheart) i find that hexwraiths and banshees are a great counter to them ( and most armies).
I use 3 banshees in a unit of 40 zombies to protect them from magic missiles early game, and use them in support of the 7 hexwraith unit .
Versus ogres keep your necros just within 24 inches of his lvl 4 mage to use spirit leech, and kite him with your redirect units, while your banshees and hexwraiths kill his support units.
Personnaly i dont think any Vc Special character is really worth its points.
If he runs a flying hellheart he will use it early to avoid being killed by death magic, so keep your lord back and get 2 lvl 2 necros with spirit leech on a zombie unit, let him waste the item on them or die before he gets to use it.
Just please dont put you caster in a GG unit, or you risk blowing your hammer up with those str10 miscast templates...
Good luck
I just played against Ogres and the only reason he got a draw was the 600pts he got from scenario... Spirit host charged, broke and ran down a stonehorn and then tied up mournfang.. :-P my lord charged out of the BK and into his ironguts and my bsb flanked them. Terror screamed and my vamps killed, broke and ran down the rest. :-) ogres have low LD, few magical attacks and have crappy save! Perfect for VC, as mentioned earlier avoid tjej dangerous charge and you win!
I'll def try the banner of swiftness with the skellies. Putting Heinrich with the GG seems like a necessary evil, I want Krell to benefit from Barrows, but I also want him to have heroic killing blow to cut through the ogres wounds, which he only has when in the same unit as Heinrich.
If your opponent forgets that Heinrich is ethereal and tries to snipe him with, oh say, maneaters, can you just let him roll to hit, then laugh and inform him he wasted his shots, or do the rules allow him to repick his target?
You declare at the start of each turn whether Heinrich is Flying or Ethereal, so if he forgot...ehhhh.
I'd also like to point out that, while this thread is about Must Have's vs OK, a general rule I try to adhere to is to not tailor as much as possible, so the idea of taking Konrad (while massively appealing) isn't really all the helpful since you aren't really learning to beat OK as much as your are throwing a hard-counter unit that was put in the book for the sole purpose of ripping Ogres apart at them and rolling dice. I will say this though, if he tailors, smash his face in with whatever!
Also, the screaming banner, combined with a Fearbomb, couldn't hurt, but you NEED terror, or else he won't be rolling any dice.
Ever try a hero wraith wall, put a VL and 4 hero wraiths in a Skellies unit of 35 + set them 5 wide..... Use your VL to kill the hero with a magical attacks
The biggest issue I have with the Wraithwall against ogres is that they tend to run a gut-star. Meaning your vamp is going to have to work really had if you want to drop 3 ogre heroes in 1 round. Although you may only have to drop 2, I don't think their BSB would have a magic weapon, I think Ogres tend to take a magic banner on their BSB, Not sure though.
This particular opponent likes to take a mundane BSB with magic weapons, he knows I usually go VC so tailors to beat ethereal. That freaking thing is invincible via sheer luck, I've tried sniping it out with death magic 3 games in a row now and it never takes a wound, and that BSBs ld rerolls single-handedly saved him from 4 breaks and 3 fear fails last game. Too bad VC BSBs do just about nothing.
Normally I run a strigoi with fencer blades and str potion, the idea is to kill the magical items before they swing also I have the screaming banner terror verse fear is still fear.if they have belly throws normally they don't have magical weapons a slather master will have fencer thou watch for this guy
An update on my latest, and most successful, struggle with the ogres.
https://www.vampirecounts.net/Thread-Big-fat-zombies
Does anyone know how Knoblar trappers really work? My opponent claimed that his unit of 10 trappers would cause my unit of 140 zombies to take 140 dangerous terrain tests upon charging, taking around 27 wounds. But that just cant be right, how can 10 knoblars plant 27 traps (or 140 for that matter)? My assumption was they could only possibly cause 1 terrain test per knoblar, or at most 1 wound per knoblar.
