screaming at dudes
Aedin said:
Mikael.K said:
Another question: the death shriek is an attack that happen in the shooting phase and can be used in close combat. So if it´s my opponents turn and my terrorgheist is in combat with one of his units, does this mean that I get to scream in his shooting phase?
No I don't think so because the only attacks that are made when its NOT your turn is in the close combat phase.
Good precedence for this is the breath weapon if used as a template it is a shooting attack made in its own shooting phase. As a close combat option it is made as a close combat attack so can be used in your opponents close combat phase.
True some spells do this in the magic phase but they specifically state so like Curse of Years.
So I only get to scream in my turns when the gheist is in combat?
Yes I would think so. There is nothing to indicate you are able to scream during the enemies turn.
[/quote]
[/quote]
That's my take on it. I wont be doing the scream on another persons turn unless i see a FAQ. Besides I have personally watched heavy cav unit disappear from that scream. I just don't see 95 points being allowed to do that twice a turn.
Smogg said:
arbogast said:
A whole list of rules don't allow the targeting of units in close combat, and that's enough weight of precedent for me.
.. and all of those rules clearly state that for this or that you cannot target a unit in close combat. It's clearly its stated every time it apply and that's enough weight of precedent for me to conclude the banshee can scream into close combat. Otherwise they would have included the limitation here as well just as they do every other place.
Actually, the general rule is that you CANNOT affect a close combat unless otherwise stated (that was what all my examples pointed to).
There is no general rule that you can target a unit in close combat unless the specific rule says you cannot. (If there is, please, point it out for us).
I would never expect a general rule to tell me what special rules cannot do. The whole concept of special rules are to overrule the general rules.
Special rules are there to tell me what I CAN do, and then provide the relevant exceptions.
-.- MOST things let you damage enemies in close combat... Spells, every other special attack including mortise engines... etc... look around.
Zhatan said:
Seeing that the scream is specified as a special attack I would resolve it as described in the "Resolving Unusual Attacks" part of the shooting section. This instructs us to use only steps 4, 5 and 6 of the shooting rules. Those are roll to wound, saving throws and removing casualties. The shooting into combat rule is under step 2 and should therefore be disregarded. This is how I see it anyway.
THIS >:/ !!!! :suck:
Who would ever attempt this. What nonsense. While your trying that, you should pull off the whipped cream genocide bru-haha. You roll a D6, and if the number ends up anything between 1-6 your entire army is sent to the moon (temporarily played by the trash can) while you scream bananas. You win the game, not just the battle, you win Warhammer. THIS is something you can attempt during another players turn.
Go on then, Quote me the general rule that you cannot target a unit in combat. All you need to do is that and the whole argument is over. Or you know you could read and understand the rules. Either or. Not an implied rule (which don't exist in Warhammer) or a rule you've just made up like your previous examples, the actual words from the book that says in general you cannot target a unit in combat.
Whilst you're there reading and understanding tell me why I can use Ghostly Howl in a units flank.
FirestormXL said:
People keep reading into Inspiring presence, it does not mention for use in tests. It says, the unit may use the generals leadership instead... for everything, not just tests...
It doesn't mention tests, but it is optional and you have to choose to use it. It says the unit may use the general leadership etc, but they're not using it, you are for your special rule. I think it could go either way in the FAQ.
There is no option according to BRB. It simply says all friendly units within 12 use the generals LD.
*Edit*
Ok so it was changed in errata but I still don't think this is an issue. They should clearly have the choice to use it if they want. It's still their unit and their general even if it is your attack.
= Let me clarify: I did not say "damage" I said affect once but meant target (as I say later). And yes, I said "general rule" instead of "general trends" in the rules.
1. "Targeting restrictions vary from spell to spell. However, unless stated otherwise the following rules apply: Wizards cannot target spells at units engaged in close combat" (p.31)
2. "Models are not permitted to shoot at enemies that are engaged in close combat" (p. 39)
3. I've already pointed out the special rules examples that do not allow it (despite the claim above).
So yes, while the shriek is neither a magical or shooting attack per se, there is precedent and general trends for not being able to target units in close combat unless the specific rule says otherwise. Hence why I would play it the way I do.
1. So spells explicitly state they cannot target units in combat, a change from the default you might say.
2. Shooting says you cannot shoot at units in combat, so another deviation from the default, yes?
So if the default is that you can target any unit you like, Spell and Shooting add restrictions to that. Ghostly Howl does not add any restriction like that, it's not a Spell nor is it Shooting.
Seems clear cut to me, unless you have any examples of Special Rules which implicitly cannot target a unit in combat without being classed as shooting attacks. I mean i've asked you over and over again for that simple quote from the rule book but that seems to be beyond your ability to do, so this should be easier for you. Oh and stick to Warhammer, the game we're actually talking about.
So maybe it would be fair to say that that either:
1) The rule was intended to prevent screaming into close combat based on the precedent and general trends for similar things. GW just forgot to add the restriction like they did all other places.
or:
2) The rule was intended allow for screaming into close combat despite precedent and general trends for similar things. In that case the rule as it's written would not go against this intend.
In either case, since GW has answered this in the two past FAQs and with different results, its disappointing that this was handled in the 8th edition rule book in such a manner that would leave no choice but to include this in yet another FAQ.
or:
Excellent summary.
This started as a fun read and just turned sad.
You guys are never going to agree and never going to convince the other of your interpretation of the rule. So why don't you just agree to disagree and play it however you and your local groups agree on playing it. If you haven't convinced the other of your point of view by 5 pages you never are going too. So until (if) GW clarifies it in a FAQ just play it as you want to. This is just a game not some great philosophical debate, take a breath drop it and move on.:silent:
1. "Some spells have a type that enforces additional casting restrictions or waives others."(p.31) *cough* so... no point there...
2. I guess the being under Part two of making missile attacks doesn't deter you, shall I make Hit and wound checks on my Scream also? There seems to be a trend of that on pages (pg.40,42,50,51) not to mention most spells that damage.
3. For every special rule example that allows it, I have two that ignore it.
I declare your argument bust sir.
+1
..............................................................................................................................................................Um, because this burns time until the FAQ comes out? That's kind of a silly question.
