Summerfield's painting trench (Grail Chapel)
I really like your Vargheist color schema! I hope you don't mind but im keen to copy your it. My army colors are blue but i really wanted my Vargheists to have good fluff feel. I want them to look like they have spent decades starving imprisoned underground, the pasty look is perfect, so bloodless and pail!
There are no copyright on colors man, go for it :)
Your necros are great particularly the red one. That mounted vamp lord is amazing. Really great conversion and the paint job is looking super :thumbsup: You should enter it in the Golden bat if you haven't already.
Thanks, unfortunatly I don't think that I will make it to the deadline since it is only about 70% done, but there is always next year I guess.
Done! It only took me 15+ hours with all the converting, prep-work, painting and basing. But now I have my Vampire Lord on a Nightmare!
Thanks for the praise, it motivates me :) Sorry about the pictures, I try to do them under a bright lamp, but the my phone camera is pretty bad and goes out of focus in extreme close-ups.
This is my new project. THE BLACK COACH!
Plan is to have it look like it is in the beginning of flight. I have drilled and pinned the back wheels with wire and also plan to cut of the horses right of, file it down and drill pin it to the tree to add additional strength, looking like it is ethereal and going through it. The flames will probably be green and have some source lighting added on the reaper and coach. The black coach itself is in the mid stages of painting, with wheels and extensive detail works left.
Update
The tree is pinned and curentlly being worked on. Spraycoated coach white and tried nihilakh oxide for the ethereal theme since I have seen som great results by other who have used it. Will drybrush it up a little with white to make it more ghostly. Still have much detail work to do on both coach, base and such, but it is coming along nicely.
Update: Black Coach Finished
I had a lot of fun painting this model, but also quite a bit of frustration. I have made no secret that I dislike finecast and unfortunately the black coach was a wreck of bubbles and contortions. Trying to assemble it was quite a challenge and a lot of green stuffing and bending was necessary for it to come together.But all in all I think it came out pretty nice.
What I learned!
1. Gold is quite possibly the most difficult color to get right. I started out with a brown base, and worked my way up using brown, mixing darker gold, brighter gold and finally silver for edge highlight. I still have a lot of improvement to do here but it look better than just trying to slab it on right from the pot.
2. Straight up black is not all that bad. I was thinking of highlighting the coach a bit using very dark grey, but found out it looked quite clean and mean without any highlighting except for natural light. I would probably not do this for many other models but in this case I think it was the right choice.
3. Nihilakh oxide wash is very good for a ethereal theme and makes a really profound impact if combined with dark objects.
4. A white base highlighted with runefang steel (mithrill silver or whatever) is very good to make silver details stand out.
In this picture you can see most of the coach. I have drilled the horses head and a steel wire/tree branch is sticking through it to help the pins in the back wheels with support. The other horse has the back thing on his head subtly glued to the branches.
Another close up. Notice the spikes on top of the coach. I don't think there where one that did not have bubbles in them.
A close up on the reaper and coach. Notice the bubbles both on the reaper hands and his scyth. Also the rose details on this side of the coach where difficult to paint as I had done extensive repairs on the cast to make it look a little bit prettier.
Reactions: robtion
Turned out really well. I like that you coach driver is also transitioning to incorporeal, nice touch. The tree really adds something too and came out well.
I feel your pain with 'finecast'. My blood knights were really bad, lots of bubbles and mashed details, and out of shape/hard to fit together.
Reactions: Summerfield
Really cool concept, and executed really well. It's something like this that turns an average model like the Black Coach into something that really stands out on the table top and attracts the eye. Love that base, that tree is excellent. Good job!
Thanks all!
Today I bought all of this:)
Plus Realm of Battle board got delivered to me yesterday.
Needless to say, I have a LOT to do in autum.
Holy crap! What have you got there? Those trees look interesting, and are those ponds or something?
Yes, those are called army in a box. They are to some degree already pre painted. I got the toxic pools, the swamp and the rock formations. Trees are from citadel and I will do them and the realm board in a autum theme color.
Otherwise I got the following
4 skeleton warriors
2 zombies
1 grave guard (already have 30 so this makes 40)
3 crypt horrors
1 mortis engine
Fortified mannor (which to my knowledge you can't get anymore)
Dreadstone blight
Chapel
Oh, and a cairn wraith.
Also picked up some night goblins and savage orcs for my friend.
Realm of Battle board from GW.
Coated brown, brushed with acrylic oaker brown, sprayed with four diffrent kind of greens and highlighted. Stone was basecoated with a dark grey, brushed up with medium grey and highlighted with white/grey mix.
I bought flock and static grass, but I don't know if I want it on the board since it sheds so much. Final touch will be to spray it with a non-glossy varnish.
The table is finished
It took me about 6-7 hours of painting and varnishing to get it done.
I had to redo some of the boarders to get it to blend in various setups and although I did not manage to get everything to perfectly match each tile, most of it does. Here is the only one I found to be a little bit off, but since there will be terrain and such I think it will be covered most of the time.
A closeup on the stone surface.
Here is a picture of how I used the spray to blend the colors so it passes through eachother and gets at least a decent transition.
GW loves their skulls. I have a theory that the Warhammer Fantasy world actually takes place long after 40K and the skulls are the remaning final battle ground of humanity.
Positions
That looks really effective, you really don't miss the flock. Would love to see pictures of the board set up for a battle with terrain.
With the skulls, yeah - the entire world has a layer of skulls under the surface layer. Makes you wonder how the plants survive.
