Varghulf - Why not?
I liked the term "troubleshooter."
I find that running 2 together is good if you've got the points to spare.
As said above, you most likely won't find them swinging the outcome of a combat that has skelies and/or zombies, and you may very likely lose your Varg due to Combat Res.
Things they are awesome for (in order of importance as I see it)
Distractions.
--The move fast and look scary. Your opponent isn't likely to over look him lurking off on the flank. Use that to your advantage. Varg is fast enough to make him hard to catch. I find he can be worth more as a threat that the enemy might have to deal with in the future than when he actually gets into CC.
Mage Assassination.
--Slam him right into whatever bunker is holding onto that mage lord and direct all attacks to the mage. Usually it's worth the trade.
War machine hunting.
--War machine crews taste good.
Any small units, under ten.
--Too small for stubborn = awesome
Skirmishers.
--Usually not stubborn unless in woods, eat'm up.
Fast Cav.
--Might just catch'm if they run, and most likely not strong enough to win CC.
@ Rothgar
Valid points stated :)
But what if that flank was, say, khorne warriors with halberds. A tough unit in combat. Sure three vargheists get twice the attacks after (thunder)stomps as one varghulf. But the gheist's lower WS and T (both have lower I) might see them get chopped up pretty badly before they get to have a say in combat. I would wager the varghulf wouldn't get ground up quite as fast and could even pull a win in that situation.
Different jobs for different units, I say.
The Varg would probably get ground up pretty good against Khorne Halberds regardless, if they bring fire (and as a WoC player, I can tell you that mine do). It should also be noted that the vast majority of units you'll be flank-charging aren't Khorne Halberds (Savage Orc Big 'Uns are also dangerous, though).
