@ Brian mage i think your statement is a bit simplistic. For example i always love to think about new nasty combinations or new usage for something, but if you just calculate the situations Zombies just suck hard.
There are so many things which actually hurt using zombies that it is just not viable anymore.
At your example mentioned earlier with the buffing stuff: wohooow you just spend 2-3 power dice making a unit which is NOT cheap (just in comparison to other
VC units they are cheap) a decent fighter, while you could have used the buff at a unit of ghouls etc. to make them wreck heavoc.
WS2; S 3; T 3; Ini 1; No armor; Still is below ANYTHING so in normal fights they just suck no matter what you do, even with the +1S/T from the lore of beasts (Lore of Light is even crappier on Zombies if you run the numbers).
-> You cannot use Zombies cost effient to fight a normal 1on1 against other core / elite units.
So that leaves us only with "different" methods to use them for gaining any benefit. Unfortunatly those things do not work really good anymore in 8th Ed.
Cast 5 Zombies behind enemy shooters, they do not even have to bother turning around to shot, they just hold the ground and kill the zombies on their attack. Even if your opponent fails the fear test he will kill 2.33 Zombies before they can attack. The Zombies then do a mighty 0.33 kills which leaves us with a combat resolution of -1 against the Zombies and 0.33 dead shooters. If the opponent passes the LD test the zombies are wiped out immediatly without killing anything.
Casting Zombies at warmachines is just hard to perform since the caster has to get very close to the warmachine and by that you probably have already another unit at your disposal to attack the warmachine.
Instant wipe-out due to fleeing through zombies does not work anymore and most other spells you could use instead of spawning zombies do more damage than the difficult terrain damage via fleeing through zombies provides.
But i think the most important issue is, that it is harder to get victory points in 8th Ed since you have to destroy whole units. If you keep on spamming 5 Zombies only to "road bump" your opponent, he will end up with a lot of +50 Victory points. Even the tactical advantage of zombie road bumps is often not enough to offset the loss of 50 Victory points.
But if you have any fancy ideas i would be very glad to hear
PS: The last sentence goes to all the ppl who say zombies should be used.
EDIT: Uh i just saw that there some additional comments from other people and i would like to comment on it, especially on StirogiPerogi because from a logical and mathematical point of view most of it is nonsense (i rally dont wanna flame
1st: If you use zombies to give cover to other units. If you would just spend the points for buying zombies on the GG unit itself you get the same benefit, since you need a lot of shots at a GG unit to reduce the number of deaths due to cover by 8 (which cost aproximatly the same as 20 zombies). If you raise zombies for the same purpose its even worse, since an IoN on the GG would revive more GGs on average than covering zombies would save by reducing the number of hits.
2nd: Zombies are not great flank chargers. True you get +1 because of flanking. True you can negate enemy ranks, so you bring +4 to the CR, but if you fight another units with a higher pts cost than 4-5, so a unit which actually justifies a charge from two units, the zombies will die in mass and reduce the CR by a lot more than -4.
3rd: Just stating that they are cheap is worth nothing. Because they are not cheap in comparison to what they are performing. A pile of shit is also cheap but still you wont buy shit like crazy because it has no use. You will also dont buy 3 front doors because they are so cheap, since there is no use for it. (jeah i am getting a bit silly here but i think you got my point).
