Skittelz1981
Varghulf
How can you roll poisonous attacks in the same roll as non-poisonous attacks?
They are two different types of attacks. First you have to roll for poisonous attacks separately so that you dont get mixed up with the normal attacks that still need to roll to hit.
At least from the first post by Sun King i get the feeling that poisonous and non poisonous attacks are being rolled in one hand just because its the same inititative?
Thats totally wrong.
If 4 attacks have the poison rule then those will need to be rolled separately, since he might miss all his poisons on 6+ which then turns into normal attacks that need to roll to hit. If you roll them together with non-poisonous attacks its easy for the attacker to claim that any 6 rolled is a poisonous autowound, which is false. That 6 might have come from a nonpoison attack and thus is not a poisonous autowound but simply a hit.
Ofc you can differentiate that with dice of different colors.
Charmed shield blocks the first hit suffered i believe.. so autowounds by poison attacks are blocked as well since its nothing else than a hit that actually wounds directly. But the shield negates the hit so wound is not caused either.
So depending on what attacks were rolled first by the attacker, the charmed shield blocks the first incoming.
If all are rolled simultaneously but with different color dice then i say its up to the defender and wearer of the item to decide what is blocked. You are the wearer, not the attacker. The attacker cannot decide for you what you legally block.
There is no rule for this situation, there is no faq. So all you are left with is common sense and fairplay.
I do not completely agree with the suggested way to play earlier.
I think that the wearer of an item has predominance over how and when to use it.
If a flurry of attacks come in simultaneously then its up to the wearer to choose what is blocked and what is not.
