Ok, expect to see updates over the coming days.
I have to say though, that most of the paint methods I'm using come from either the GW site or other tutorial sites.
Anyway:
Word of Warning
One small warning beforehand concerns painting the model in parts and assembling it afterwards. I always try to piece together before priming it to see if everything fits. HOWEVER, while it may fit together perfectly while still grey, once it has been primed and painted it tends to be a tiny bit thicker which may lead to the pegs not fitting in the holes. Therefore, I always take a round file and widen the holes a bit to make it easier to assemble afterwards.
PART 1
Part 1 is probably the dullest stage in the painting of this thing as it basically consists entirely of painting some wood with some tiny metal parts. However, as this covers the chassis and crossbeams that hold the entire model together, it's also a very important one.
No assembly required yet on these pieces as they are solid chunks of plastic, so I'm going to skip to the painting step.
Basecoat
I have a standard method of painting wood, which is a slightly adapted version of the one GW suggest on their site. At this point you don't have to worry about neatness as you're going to cover the messy bits after this anyway. I start by basecoating all the wooden parts with a 1/1 mix of Bestial Brown and Fortress Grey. This makes sure the wood isn't going to be too saturated and approaches a more natural colour than pure Bestial or Scorched Brown would.
After this layer is completely dry, drybrush the wood lightly with fortress grey. Would tends to become grey as it ages, so we're going for realism here.
Dirtying it up
If you want a less uniform and decrepit look, you can pick out the occasional wood beam or panel with a glaze of Dark Angels Green or Dark Flesh.
Metal
The next step is picking out all the metal bits. Be careful while basecoating them (use Boltgun Metal for this) not to paint metal on the wooden parts. It looks really bad and you don't want that.
Playing with mud
Now it's time to break out the giant pot of Devlan Mud and give the entire model a heavy wash with pure Devlan Mud.
Final details
Leave this again and once it's dry, highlight the edges of the metal parts with mithril silver. You can leave it a this stage, but I like a bit of rust. Skaven don't tend to care for their machinery once it's been built, so rust is sure to form. I paint my rust in a very simple way. I stipple Bestial Brown in the areas I want rust and then stipple Blazing Orange on the same area leaving some Brown showing through.
One thing to keep in mind when playing with rust is that it doesn't for in random locations. It always begins forming in areas that collect water, like the underside of metal bolts.
Picture time
The end result should look something like this.
Keep in mind that this is meant for tabletop quality. If you really want to push it, you can add further drybrushes or highlights to make it look even better.
As you can see I also didn't paint the axels as they aren't going to be visible in the end anyway.
Cheers, Wolfie
Edit: I apologise for the picture quality which is horrible. The metal came out good, but the wood seems to have lost all colour and highlights due to the flash.
