Finished the bell and thought I'd post up all the parts together so you don't have to sift through the thread for the different parts.
Word of Warning
One small warning beforehand concerns painting the model in parts and assembling it afterwards. I always try to piece together before priming it to see if everything fits. HOWEVER, while it may fit together perfectly while still grey, once it has been primed and painted it tends to be a tiny bit thicker which may lead to the pegs not fitting in the holes. Therefore, I always take a round file and widen the holes a bit to make it easier to assemble afterwards.
PART 1
Part 1 is probably the dullest stage in the painting of this thing as it basically consists entirely of painting some wood with some tiny metal parts. However, as this covers the chassis and crossbeams that hold the entire model together, it's also a very important one.
No assembly required yet on these pieces as they are solid chunks of plastic, so I'm going to skip to the painting step.
Basecoat
I have a standard method of painting wood, which is a slightly adapted version of the one GW suggest on their site. At this point you don't have to worry about neatness as you're going to cover the messy bits after this anyway. I start by basecoating all the wooden parts with a 1/1 mix of Bestial Brown and Fortress Grey. This makes sure the wood isn't going to be too saturated and approaches a more natural colour than pure Bestial or Scorched Brown would.
After this layer is completely dry, drybrush the wood lightly with fortress grey. Would tends to become grey as it ages, so we're going for realism here.
Dirtying it up
If you want a less uniform and decrepit look, you can pick out the occasional wood beam or panel with a glaze of Dark Angels Green or Dark Flesh.
Metal
The next step is picking out all the metal bits. Be careful while basecoating them (use Boltgun Metal for this) not to paint metal on the wooden parts. It looks really bad and you don't want that.
Playing with mud
Now it's time to break out the giant pot of Devlan Mud and give the entire model a heavy wash with pure Devlan Mud.
Final details
Leave this again and once it's dry, highlight the edges of the metal parts with mithril silver. You can leave it a this stage, but I like a bit of rust. Skaven don't tend to care for their machinery once it's been built, so rust is sure to form. I paint my rust in a very simple way. I stipple Bestial Brown in the areas I want rust and then stipple Blazing Orange on the same area leaving some Brown showing through.
One thing to keep in mind when playing with rust is that it doesn't for in random locations. It always begins forming in areas that collect water, like the underside of metal bolts.
Picture time
The end result should look something like this.
Keep in mind that this is meant for tabletop quality. If you really want to push it, you can add further drybrushes or highlights to make it look even better.
As you can see I also didn't paint the axels as they aren't going to be visible in the end anyway.
Alright, long time since I posted here. The finger proved to be more trouble than the doctors thought it would be which meant it took longer to heal which in turn meant I got behind on school work so it took me untill last week to catch up with everything. Unfortunately my exams are coming in 2 weeks, so it'll be a while before I can get back to painting a lot, but I managed to do some things in between.
Anyway, here's the second part of the Screaming Bell tutorial.
PART 2
Part 2 consists of the large wooden frames that make up the biggest part of the structure. The might seem as if they're a pain to paint, but aside from the ropes, it's very fast and easy.
Wood frame and iron
The biggest part of this is the wood frame and the metal holding it together. This has been painted exactly the same way as the wood and metal of the chassis, so I'm not going to go further into that.
Stone
I always disliked the clean feel the stone on the GW Screaming Bell has. I imagine the Skaven don't actually take the time to make new things. They just go out and fish some part of an old building out of the Great Marsh. Having been submerged in stinking water like that, I thought it'd be covered in slime, mud and algae so I tried to make it look like that on my bell.
I started of with a basecoat of a 2/1 mix of fortress grey and chaos black, which I then drybrushed with pure fortress grey.
To get the muddy feel I then simply washed it twice with Devlan Mud. After this has dried, I washed certain areas of the stone with a 5/2/1 mix of water, Dark Angels Green and Chaos Black. Leave some areas alone because moss and algae, generally don't cover an entire area, but leave patches showing through.
If you're feeling really ambitious you can even try to paint on some lichen.
Ropes and cloth
The ropes and cloth were both painted the same way. Start of with a basecoat of Khemri Brown and wash with Devlan Mud. After the Devlan mud has dried out you can highlight/drybrush both with Khommando Khaki.
After this you are done, but I went a bit further with the ropes. As the Great Marsh is probably a moist area you are going to get the same assortment of algae and moss in the rope (yes, in, the outer rope generally stays clean). Check out some old rope hanging of a peer or boat and you'll see what I mean. I achieved this with the same washes I used on the wood only I was a lot subtler in applying them.
An explanation on washes
If you bothered to read this entire thing (if you have I'm already 1 ahead of my prediction
) you will have noticed that the same washes tend to come back over and over again. This is because of two major things.
1) I tried to emulate what materials recovered from a swamp might look like.
2) This is the most important. It ties all the different parts of your model together by making sure you have a pallet of colours that fits together. even if I would've gone for the clean stone look, i'd have very lightly glazed it with Dark Angels Green. You might not have noticed it, but it'd look a lot more natural than if it wouldn't have been there.
The next part (after the second side is done) will focus on the metals for the bell itself and the warpstone fumes.
PART 3
As most of the carriage has already been painted, I've begun painting on the most important part of the model. I took the most care painting this part as logic would suggest that this is the part the Skaven would take most care building and maintaining.
Metal
The first stage consists of basecoating the metal parts in a 1/1/1 mix of Scorched Brown, Tin Bitz and Dwarf Bronze. After this I pick out the the iron bits with Boltgun Metal. Wash the entire area with Devlan Mud once and wash the bronze part a seond time after the first layer is dry. Highlight the iron bits with Chainmail and add rust. After this highlight the bronze with a mix of Brazen Bradd and Dwarf Bronze. Once this is dry, add Verdigris by washing the recesses with watered down Hawk Turqouise. Be careful that you thin it enough to avoid big blobs. You can always go over once more to make it pop more, but you cannot undo it if you go to far.
Bone
The Skaven army book mentions that at least a small part of each SB is made ftrom a part of the great bell in the middle of Skavenblight. This is what supposedly gives the bell it's power. However, I wanted to add a bit more detail to the bell in the form of bone inlays. Easy explanation is that the grey seers use the bones from Vermin Lords (Yes, I know daemons don't have bones, but if GW can change fluff every 5 minutes, so can I.
) to grant the bell it's mystical powers.
The parts I painted in bone are the 2 horns on the side of the bell and the rat faces on the front and back. I used the same bone recipe I used for all my bone, which is a basecoat of Scorched Brown highlighted with Bestial Brown, which is in turn highlighted by adding more and more Bleached Bone to the Bestial Brown.
After this was finished, I picked out the eyes of the skull with red and highlighted with Blazing orange and a white dot to make them look like gems/
Warpstone
I have an easy recipe for warpstone. Make sure the entire areas is black and wash it with Black Ink. This gives a glossy look which I find goes well with warpstone. Highlight with pure Dark Angels Green and add Scorpion Green untill you are satisfied with the highlights.
Pictures
You'll notice in the pictures that the top half of the bell isn't done yet. You can paint it any metal you like, but I haven't figured out yet what colour I want it to be.
@ U_M: Your wish is my command.
Small update.
PART 3.5
This step is basically finishing the detailing on the carriage and bell. The main thing to do at this point is paint the Warpstone smoke and glueing the bell in place. To make my life a bit easier, I beginning with the Warpstone.
Warpstone
The base colour for the warpstone is Dark Angels Green. Once the basecoat is dry, layer on Snot Green leaving only Dark Angels Green in the recesses. Repeat this process by adding Fortress Grey to the Snot Green untill you end up with pure Fortress Grey. As a finishing touch, add a final highlight of 50/50 Fortress Grey and Skull White.
Glueing the Bell
I'd be surprised if any of you don't know how to glue something together, but I've got a handy little trick for glueing the bell at the correct angle without having to stand around holding it till the glue is dry. If you take a look at the bell you'll see that it has 2 little horns on the side. Glue the bell into the 2 masonry bitz and angle it correctly. Nex, insert 2 brushes behind the horns to hold it in place. Use your Rat Ogre to see at which angle the bell should be.I've included the picture to show what I mean.
To make transporting the bell a bit easier, I've left the top halves of the masonry unglued so they can easily be removed.Simple but effective.
PART 4
With the carriage done, Quasimodo's up next. Not a lot of new things here, just the skin and fur.
Skin
The skin's the biggest part of this Ogre, so I put in some extra steps in highlighting.
First step is basecoating with Tallarn Flesh. Once this is dry, wash the entire model with watered down Scab Red. Leave this to dry thoroughly. Rehighlight the skin with Tallarn Flesh leaving the red in the recesses. Highlight again with a mix off Tallarn Flesh and Bleached Bone. Repeat this step adding more and more Bleached bone up until a mix of 1/3 Tallarn Flesh/Bleached Bone.
Fur
The fur's really easy. Start by blacking out the fur areas again. Basecoat it with Scorched Brown. If the fur isn't entirely blacked out before this step, it's going to be all blotchy. Leave it to dry completely and drybrush with Graveyard Earth. And voila, finished.
Blood
Quasimodo's holding a spiked chain which is digging into his skin, so obviously it's going to bleed. To paint the blood I mixed some Tamiya Clear Red with Purple Ink and left it to dry for a short while. This'll make the paint a bit chunky like clotting blood. Paint around the chain on the flesh and on the open scars. If you want you can paint some blood on the bandages on his eyes, to make it look like blood is seeping through.
The metal, cloth and horns should be easy to paint by using the techniques allready covered in the previous parts of the tutorial or by using your own colour scheme.
As always Comments and Criticism are appreciated.
Cheers, Wolfie
