Hopefully yours doesn't explode like mine did!Haha same, I’m looking forward to painting, he’s much better than the GW version.
This happens because if I cured resin inside. Basically if it’s been hollowed out it needs drain hold or a gas builds up.Hopefully yours doesn't explode like mine did!![]()
That's exactly what happened, and my print guy took a "not my fault" stance because "my Warlord titan hasn't had this happen and I did the same thing with that as your Skarbrand".This happens because if I cured resin inside. Basically if it’s been hollowed out it needs drain hold or a gas builds up.
Sounds like you need a new print guy *waves*That's exactly what happened, and my print guy took a "not my fault" stance because "my Warlord titan hasn't had this happen and I did the same thing with that as your Skarbrand".
For context: The Warlord Titan has actually had the pop/crack since then, but didn't have liquid resin trapped inside it. My Skarbrand did :/
Couple of test khorne warriors.
Second time this had happened. I deleted the post last time.weird. In the OP I cannot see the pictures, but they appear when i reply to the post.
Images are broken again![]()
Some minor tweaking, but he’s pretty much done now.
These worked fine on warseer and dakka dakka…Images are broken again
And now they're working. WeirdThese worked fine on warseer and dakka dakka…
