Najo's Battlescribe Catalogs
I just added the force to the same file as the standard force, updates the revision number and then updated the repository. It found the end times force option, but it's blank.
So if I go through and copy the I'd for each category into the new force's corresponding category it should work?
Edit: I copied and paste. Seems to be working! Thank you Jon! I owe you a beer!
Great work! Much better then the old versions I was using. One oddity I noted....When I created an army in your new system that was completely identical to one I had under the old catalogs I was using, the army came out as 1 point more expensive. Not sure where the discrepancy was, and truthfully If there was an error It was most likely an error with the old catalogs.
Thank you :) Which catalog had different point values? Vampires or Undead Legion? Now I curious what the discrepancy was :P
Thank you :) Which catalog had different point values? Vampires or Undead Legion? Now I curious what the discrepancy was :tongue:
Found it! Which is good, cause it was driving me nuts as well lol.
The old catalog I was using for Vampires had a Great weapon for a Wight King listed as 4 pts. Your catalog has the correct point value of 5 points. Hence the one point difference.
Reactions: najo
Thanks for your hard work on the legions list @najo, I found a error or im blind... it seems lich priests cant take tomb kings arcane items?
Thank you! Yeah, looks like I accidentally left out the army book items. I'll get it fixed. Good catch!
The version that I've just checked out doesn't have the 50% Lords/Heroes allowance? Maybe I've somehow gotten the oldest file?
You should be able to choose between standard force and armies of the end times force. It's in the menu when you choose your army list.
First, thanks for this Najo! It's awesome. 1 mistake i've found in the UL list was the tomb king magic items.... the Talisman list has been replace by the enchanted items list (so 2 enchanted items lists under the magic items menu).
Fixed! And thank you :)
With the fixes you're implementing, do I need to update my data files or will I need to redownload?
I wish we still had +Rep. I'd be repping your bones off.
Thanks Adam! You should be able to just hit update and it is fine. If you have other files in there you want gone, like the old vampire catalog for example, you can delete your days and re sync with my link and it will give you nice, current clean catalogs that I use.
Side note to everyone, if there is anything you want changed or added into catalog, let me know. I can also work with other players who type up rules and other text for me. For example, you want an army catalog to have descriptions of the magic items or special rules not in there. Type them up, and I will copy and paste them in.
Reactions: Tobias the Mad
Thanks for the vlad fix. A friend of mine said something about there being an issue on night goblins, something about weapon options.
ok, ive duplicated the issue for a unit of 25 night goblins. First, the hand weapons are weirdly listed per model to start, while the other options are just check boxes for the unit. The hand weapons option becomes a checkbox after zeroing them out. If you give the unit spears and not handweapons, you get the following two errors:
Night goblins has 24 too many options for spears and shields (maximum one)
Night gonlins must have 24 more selections from weapons (minimum 25)
amusingly it both thinks you have made 25 selections when you can only make one and simultaneously thinks you have made only one selection when you must make 25.
the problem doesnt seem to create points costs or usability problems, just some awkwardness and a couple unneeded error messages
Thanks alot. I was sick and tired of the program crashing every time I tried to open any of my Characters
Keep Up the good work.
EDIT: I have encountered a crash after equipping a Cursed Book on a Necro. I have not been able to repeat it yet but I'll get back to you if I can get any useful information.
Reactions: najo
Can someone help me with adding the datafiles? I've tried copying the link provided and I just get a ton of errors and can't update it, and I've tried downloading the file (index.bsi) and adding the file with the file manager but that causes the same errors. I've tried reinstalling battlescribe and I've removed all other data repositories.
