Santa's Workshop : NSFW Kharn
RE: Desert Camo
I'd suggest starting with the bottom colour (in this case Desert Yellow should do the trick), shade it as you would a normal flat colour and then paint on the patterns using the appropriate colours. Shade the larger patches again and then add on the tiny spots. Just try to get the base colour down first.
Oh, I found a tutorial as well. Probably not the exact camo scheme you want, but should be some help at least.
Cheers, Wolfie
RE: Desert Camo
I think you want something a bit lighter than Desert Yellow actually. I use Desert Yellow as the base color for my FoW European Theater Germans, and that's clearly not what you're gunning for.
I assume you're giving your nephew a mini as a present. If the mini is a vehicle, you may want to drybrush the base color on. If you flat paint the base on the vehicle would look 'clean', and combat vehicles of all sorts almost never look like that unless they have never been used in the field.
RE: Desert Camo
here is an IG commision army I did in desert camo
it's quite easy to pull off. just start with a grey dry brush a lighter grey then get three off the desert camo colors you want and make Y's all over the model and do this overlapping with all three colors just barely leaving the undercoat of grey coming through. For 54mm scale you will probably want to do some undercoating on your Y's so first lay down a darker color then almost highlight the darker Y but paint over it so that just the edges are showing. this will give definition to your camo. It's a neat little trick that has worked for me happy painting. xD
RE: The Armies Of Chaos Updated 12-7-10 mauder Undivided standard bearer
Looks good. Standard seems as if it could be used as a blunt weapon. :)
Cheers, Wolfie
RE: Dragon Legion Updated 12-7-10 Reaper Blood dragon figure.
Looks kinda androgenous,it also has knucklebutt(it is what it sounds like).
Good paint job though.
Santawraith said:
There was a time I thought I knew english then I met you count.
Heh! xD
I quite like this new vampire and it is really nice to get a present in forms of a painted warhammer miniature. You've done a good job painting him, your friend will be glad to receive it. :)
isn't it androgynous ? :P but nice painting , keep it up :)
RE: Dragon Legion Updated 12-10-10 Undead Centaur
My bitz box. it is made by dark horse miniture company. Which was around for a short period of time. You can still find them on ebay every once and a while. they never made a big break into the miniture world and went belly up soon after opening.
aw shame cause i really like it ah well ps great work :):vampire3:
ya i'll give it a look whats the name of the actual model or should I look up undead centaur ?
edit nevermind found them :P I think i'll get one hopefully thanks :)
I really dig that centaur,a unit of them would make good black knights.Might be a good conversion project w/skeletal horses and maybe GG parts..hmmm...gears turning....
