Wall-o-Wraith and Spears - how to make Skeletons a fighting unit in 3 easy steps!
In which case you're sacrificing your units effectiveness at cancelling out steadfast and absorbing casualties for a mishmash of minor sidegrades that are unlikely to help you at all, much less significantly. Not to mention the unit will still cost 25 points more.
I will only ever field zombies as a bunker for my necromancer/s. There's a few reasons for such.
One, the models look terrible. Of all the new models that came out, why did GW not deem it necessary for a zombie upgrade? They look like they're from a bad horror comic from the 80s.
Two, zombies are beyond worthless in combat. I've watched 60 zombies crumble to 8 zombies in a single round of combat. Sure, the skeletons would probably have been butchered, too, but they're slightly less worthless than zombies are.
Given that, I don't think it really makes the unit that much less effective, Underlord. Remember, you get a banner, musician, AND champion with the skeletons. (Slight) Bonus to CR, swift reforms, forcing allocation against the champion if need be, and the possibility of a magic banner, in my opinion, far outweigh any bonus you could have from fielding more zombies.
aussie said:
lol to be honest played the willo wisp wall and there great.... until the jugde rules that a unit with a flamming banner has magical attacks too. Because a gw rep is saying there playing it as that grrrr.
Ouch.... pretty brutal that they ruled this way since magical and flaming are pretty clearly two differnet special rules and the banner only grants one of them ... I see how one could argue this (it is a "magic banner") but RAW would seem to say that they are not flaming/magical in the same way that casting a spell that gives a unit poison, does not give them poison/magical (or would they have ruled that is true, in which case my gobo's just got a lot better... :))
On topic, thre is a lot of hate in this thread but I have to say the most balanced answer is as was already posted. Bring a unit of skels and a unit of zombies and deploy the wraiths as you see fit.
Another option is that if you really don't like the idea of wraiths and skeletons is to not field it at all. Problem sovled, no need to argue it any more.
I am honestly more interested in hearing examples of how either has worked (zombies or skeletons) than hearing about why it should not work. I myself am going to have to try out both, if only to see the look on my buddies face that first time I tarpit something big with no magical attacks at all :)
Krys
I used 35 skeletons with a wall of wraiths. No magic banner.
They held up my friend's Gor unit for three FULL turns (meaning 6 rounds of combat) before they finally died. He had one character with a magic weapon. This unit is an excellent anvil in most circumstances.
As the Beastmen player he's talking about, I can tell you it wasn't quite that effective (it lasted 3 rounds, not turns), but that was because I managed to get an ideal situation - a unit of ambushing Gors was delayed until after the Wraiths had gotten engaged in combat, and I rolled a 6 on the ambush dice. Naturally, I placed them right behind the Wraiths and rear-charged them in the following turn, plus I had a Razorgor doing its thing in the flank. In a one-on-one, that Wall-o-Wraith might have actually won the first round and had me test.
As Rothgar mentioned earlier, the 'Make way' rule allows you to handle a pesky flank charge so long as you don't get charged from 2 directions at once. Use zombie tarpits to avoid that. I think 20 skeletons (including full command) is ideal. If you want the magic banner...fine. Here is why. 20 skellies plus the 5 wraits is a 25 man unit. 5 x 5. IoN will likely keep the unit capped off. ;) In other words, you'll likely stay at 25. With this nice brick you can use 'make way' to reposition for a flank or rear charge and never have your skellies touching the enemy. Since spear give you the ability to fight in two extra ranks when defending, might as well take them. The extra 10 attacks can't hurt.
I also like 25 because it is a smaller foot print. The unit is less likely to get in the way than say 50 zombies.
I understand that the small size makes it more vulnerable to magical template attacks.
Negating the flank charge and Warham owning my skeletons, I would have won the first round, actually.
Yeah, it was only 3 turns of combat. Sorry, I was too busy thinking of all those 1's I rolled on spells.
Correct me if I am wrong, but from the way I am reading the mini battle report, the Wraiths were engaged in the front before they were flank and rear charged. The way I understand it, you can only make-way if your unit is engaged in CC and the character/s are not. So repositioning them to the side with the most choppy unit wasn't an option.
You're correct.
That is correct, and it's also what was implied, if it wasn't said outright. One of the weakness of the unit is combo-charging, because the Wall is really only effective to one face.
And THAT is why you need zombie tarpits/speed bumps on it's flanks.
This goes without saying if you're a VC player. Any unit you want to stay alive you need to keep from getting flanked, period. Grave Guard, Vargheists, Wraith wall, whatever it is. We are far worse off than most other armies getting flanked because of crumbling wounds.
The wraith wall can do nil against daemons. I ended up dropping my wraiths as I expect a lot of daemon players at adepticon and I dont wanna have 300 wasted points. I opted for a large block of GW graveguard instead.:thumbsup:
Yeah, well, screw Daemons.
I understand this unit is an absolutely worthless match up against any Daemon list. In general, though, VC do not match up all that well against Daemons.
It shouldn't be an either/or thing. You should have this in addition to the giant block of Grave Guard. But yeah, Daemons are a painful matchup for this unit.
Everything has it's Achilles heel in the game. If there was a totally unbeateable unit, everyone would have it.
Teclis
fateweaver
hydra's
Suppose your right. ;)
Tomb King said:
Teclis
fateweaver
hydra's
None of our Tournaments allow special Lord characters (but I imagine Teclis dies much easier than an ethereal Slann Lord...). I've killed plenty of hydras in my time so they are not unbeatable.:tongue:
The Dead King Of Dead Stuff said:
im sure this is an effective unit for a tournament style game but i usually play with friends and i seriously doubt i would HAVE many friends left if i ran this in my army often.
Might be effective for a tournament, might not.
However, just tell your friends what you will run before hand and let them taylor a list for this unit. That's what I do! Unfortunately, if someone is expecting this unit it is FAR less effective.
I just wanted to point some things out from experience.
Even though it will last for a few rounds of combat, a 450 point unit is not worth taking if it cannot generate combat res of it's own.
Wraiths, as I've discovered, have issues against most units due to their lack of weapon skill. They NEED to buffed in order for them to do anything in combat.
Always striking last sucks. Against anything with a magic weapon, it means at least one dies before it gets to swing. That defeats the purpose of this unit.
Regarding a character with a magic weapon. This unit actually needs 6 or 7 wraiths. A wraith absolutely needs to step up and fill the place of another wraith. The unit champion is not enough.
The problem is that would a 510-570 point unit like this be worth it?
What do you guys think?
rothgar13 said:
That's tough to say. There are only so many Hero points to go around.
Tell me about it.
There ARE enough hero points for several more wraiths, but the rest of the army suffers for it.
Decisions, decisions.
what about using this unit as your bodyguard for a defensively tooled combat lord?
The enemy RnF are guaranteed to throw maximum attacks at him, so the Ghoul king's lesser defences probably wouldn't suit, but a vampire lord could generate some damage and the unit supplies ranks and ethereal staying power, plus whatever damage the wraiths do and it'd save you the cost of a wraith... it's just too bad theres no ethereal vampire power anymore.
Sure it'll be effective. Then again, any unit that costs circa 1000 points should be pretty effective...
