Anilar(Wood Elf ) vs. Sweeney Todd(VC) 2500
Status
You failed the combat reform Ld test, because the same modifiers that apply to your break tests also apply to combat reform. So in this case, you would have to take the Ld test at -3.
Something weird is happening when I press next turn, your new zombies place it self at a new angle. And my dead eagle reappears in combat with your Vampire and black knights. Does the same happen for you, or is it my program that screws it all up.
Well I can declare charges, not that you can do much but hold, but want to hear if you face the same problems as me.
Treeman will charge your Freshly plucked zombies, he needs some new fertilizer, and decomposing bodies should be a rich source for that I have heard.
My Noble on Great eagle will charge your blood knights in the flank.
Treekin will charge the annoying bats, hate them since I usually see them used as mobile cover for units, I really want to shoot at.
My D2 dryads will charge the forest spirit in the forest.
I think the only unit I need to roll for is my dryds, needing a 5 to reach it.
Not sure what is happening, tried to skip a few turns ahead. It seems my eagle has decided to return every turn. Your old and new zombies have a mind of there own and such. So guess we are going to do extra work everytime we update the map.
Time for magic.
That was a rather powerful dispel. Now don't overdue the powerful dispels.
I will dispel my shield of thorns and throw it on my Noble on eagle in combat with your blood knights.
Cast on 9+ throwing 3 dice at it.
Str 10 hits on the BSB and 2 Glade guard. Not sure if I can do a look out sir on this.
Rolling 4 dice, the first will be look out Sir, if its possible otherwise we will just ignore it. Second will be the hit on the BSB or unfortunate hero that steps up.
Status
