They use fluffy/ casual lists instead of using the power gamer lists, to try and show the abiltiies of the various units. They arent rubbish, they just arent tourny lists that every seems to like using.
SirKoozzi said:So can sombody scan the pages and post it?:happy:
SirKoozzi said:I know but we dont have GW store in poland...
Disciple of Nagash said:If only it could be cleared up whether they have access to magic weapons?
N.I.B said:Very promising rules.
5 hero Wraiths in the front line of Skellies - cast Vanhels on them and they strike first with reroll with 5 S5 attack that autowounds and allow no armour saves, and can't be hurt back (if you played your cards right) and are backed up by static CR. The narrow unit width and Lord of the Dead help you to break enemy Steadfast. This unit will be awesome against some armies, and they are easily allocated to the unit you need them in, with their 12" march.
And I like the models although they seem brittle.
Swissdictator said:N.I.B said:Very promising rules.
I seem to recall command *must* be in the front rank unit, displacing characters to the second rank. So you couldn't have any command at all. With the low unit count we can have, especially those with standards, we'd likely at least want a standard... so it would still allow some attacks.
Normal layout
WCBMW
WsWsW
sssss
sssss
sssss
sssss
Make Way layout
WWWWW
CsBsM
sssss
sssss
sssss
sssss
Disciple of Nagash said:Now on the other hand using the to hold up those annoying skirmishers, fast cav or flyers, all which generally lack magical attacks, sounds good.
